itsandil
UTF8 to EBCDIC conversion help - Cp420
I am trying to read an Arabic string from a UTF-8 file and then convert the string into EBCDIC - Cp420 charset. I've been struggling with this and any inputs on what is the best way to do it with references/links to sample source code will really help.
I've tried using a BufferedReader and then encoding the values, as well as read a UTF8 string and then use the getBytes("Cp420") invocation to return my requirement, but to no avail. I believe I am missing something here but can't put a finger as to what exactly it is.
Incidentally, when I use the Charsets.availableCharsets () method, I do not see the Cp420 charset on the output - appreciate any assistance regarding this.
Cheers,
Sandil
Cheers,
Sandil
The data in the output file seems to be garbled.
I tried replacing the OutputStreamWriter with a ByteArrayOutputStream and then writing the contents of the resulting byte array to console/file/dataqueue on iSeries but they resulted in a blank string.
I suspect the Cp420 charset might not be included as part of my JDK installation - is there anyway to confirm this? I do not find it in the rt.jar as well.
Cheers,
Sandil
Cheers,
Sandil
>>my JDK installation
... which is ..?
... which is ..?
sun/io/ByteToCharCp420.cla ss IN C:\j2sdk1.4.2_09\.\jre\lib \charsets. jar
sun/io/CharToByteCp420.cla ss IN C:\j2sdk1.4.2_09\.\jre\lib \charsets. jar
sun/io/ByteToCharDBCS_EBCD IC.class IN C:\j2sdk1.4.2_09\.\jre\lib \charsets. jar
sun/io/CharToByteDBCS_EBCD IC.class IN C:\j2sdk1.4.2_09\.\jre\lib \charsets. jar
Please post your current code
JDK installation is 1.4.2. I can see the CharToByteCp420.class in the charsets.jar, but when I try to create a Charset for encoding Cp420 I am returned with an unsupported charset exception, hence I've reworked it to play purely with the BufferedReader and the OutputStreamWriter objects.
My current code is as follows:
import java.io.*;
import java.nio.*;
import java.nio.charset.Charset;
import com.ibm.as400.access.*;
public class ArabicStringToEBCDIC
public static void main (String args[])
try
// System.out.println(Charset .available Charsets() );
AS400 as400System = null;
as400System = new AS400();
as400System.setSystemName( "172.16.5. 11");
as400System.setUserId("XXX ");
as400System.setPassword("X XX");
as400System.connectService (AS400.DAT AQUEUE);
DataQueue dq = new DataQueue(as400System , "/XXX.LIB/XXX.LIB/XXX.DTAQ ");
dq.clear();
BufferedReader in = new BufferedReader(new InputStreamReader(new FileInputStream("arabic.tx t"), "UTF8"));
ByteArrayOutputStream baos = new ByteArrayOutputStream();
Writer out = new OutputStreamWriter(baos , "Cp420");
int buf = -1;
while((buf = in.read()) > -1)
out.write(buf);
System.out.println(baos.to ByteArray( )); // throws a value to console, [B@1f14ceb
System.out.println(baos.si ze()); // returns 0
dq.write(baos.toByteArray( )); // throws an exception as the byte array size is zero, surprisingly
catch(Exception e)
e.printStackTrace();
NOTE: I also tried your method using the file output stream as follows:
Writer out = new OutputStreamWriter(new FileOutputStream("arabic-e bcdic.txt" ), "Cp420");
... // do the conversion
out.close();
and then reading the resulting file and writing it to the dataQ which again resulted in a zero length string being registered in the queue.
I don't see any issues in the queue as I am able to do a pure EBCDIC to EBCDIC transmission. If only I can find out why Cp420 is not part of my available charsets and why I'm not able to create a Charset object for that encoding.
import java.io.*;
import java.nio.*;
try
dq.clear();
int buf = -1;
out.write(buf);
catch(Exception e)
out.close();
Have you arranged for the existence of that file? If yes, can you please upload it to this site?
Yes, I have arranged for the existence of this file.
You can download the arabic.txt file from this link
http://labs.sandil.com/support/ee/Java_Q_21858234/arabic.txt
And the resulting EBCDIC converted file at
http://labs.sandil.com/support/ee/Java_Q_21858234/arabic-ebcdic.txt
Cheers,
Sandil
Cheers,
Sandil
OK. What makes you think that that Arabic is encodable as EBCDIC? AFAIK, the latter is just an old species of ASCII ...
http://publib.boulder.ibm.com/infocenter/txformp/v6r0m0/index.jsp?topic=/com.ibm.cics.te.doc/erziad0058.htm suggests that the 420 codepage/charset is what is used to encode Arabic characters on the i-Series platform in EBCDIC.
We have applications that run within the AS/400 environment which capture, store and manage arabic information in EBCDIC, hence I should believe that it is encodable. I am looking for a means of conversion, even if it is native to As/400 or means running my Java code in the AS/400 environment.
>> You need to have installed Additional Character Set support
Any tips on how to go about this? Or will the JDK 1.5.x release (multi-lingual / international edition) sort it out?
Cheers,
Sandil
Cheers,
Sandil
Well you can try installing multi-lingual support with the installer you already have (if you've kept it) but if you can update, i would
int buf = -1;
while((buf = in.read()) > -1) {
out.write(buf);
// Close all
