Solved
Printing problems in Citrix MFPS3 - Default printer and auto creation problems
Posted on 2006-05-24
Last Modified: 2008-01-16
Hi there,
2 main problems i am looking at with Citrix setup at the moment.
1 - the default printer seems never to be retained. A user logs on, sets the default printer and logs off. Logs back on and it has reverted to another printer? Can this be stopped, or at least set on a client / user basis.
2 - the auto creation printers - i want to retain the clients printers being autocreated upon login, however i do not want everbody else to see these printers in the printer list! Is there any way that i can set it so that the relevant session only looks at the relevant client printers and obviously any that have been setup for auto creation from print servers.
Thanks in advance.
Regards
Question by:utilize
3 Comments
LVL 18
Expert Comment
by:mgcIT
1 - Depending on how you have your citrix farm configured, the default printer will be set to whatever the user has set on their local workstation when they log in.  It doesn't matter what they do while in citrix.  If you have it set to autocreate their default printer then each time they log on their default printer will be set as the same default printer as their workstation.
2 - Users should only see their auto-created printers and any other printers you have installed locally on the citrix servers.  If they see all printers I bet you have everyone set as Local Admins to the citrix server (which is probably not a good idea).  Make sure the users are not in the Admin group of your server.
Author Comment
by:utilize
1 - Is there any way around this? The reason i ask is because i want them to use the default printer they set it to. Not the clients default printer.
Where/how can i turn off the local client printer defaulting and enable user customisation of printing defaults?
2 - Will have a look into this - i have a bad feeling they are set to Administrators, due to a Sage v12 problem.
Thanks for you help!
LVL 13
Accepted Solution
by:
gsgi earned 2000 total points
It is easy to turn off client printer redirection at the server or on the individual workstations.  I do it at the individual workstations.
In the documents_and_settings/username/application data/icaclient/appsrv.ini file set
(the application data folder is hidden - in control panel choose folders and click the option to see hidden folders and files)
CPMAllowed=Off
about the appsrv file :
http://support.citrix.com/kb/entry.jspa?entryID=850
From citrix forums
Anthony Barr
Re: disable client printer mapping...
... this can be achieved for all Servers within your farm by creating a policy within the CMC and disabling client printer mapping there.
Hiep Nguyen
Disable client printer mapping on a per user basis
Posted: Jan 17, 2005 6:34 PM
We have some apps that we want to prevent users from being able to print to their home PC. Is there a way to achieve this on a per users or application basis ?
Thanks. vincepps
Re: Disable client printer mapping on a per user basis
Yes. Create the Citrix policy Client devices=>Connect client printers, enable it, uncheck "connect client printers at logon" and assign it to the concerned users.
Vincent
http://support.citrix.com/article/CTX681954
http://support.citrix.com/article/CTX108124&searchID=17971912
I am working on a registry fix for this myself.  If you'd like to discuss it offline you can e-mail g-r-e-g-btreetechnology-com ...
gsgi
We value your feedback.
#CITRIX #XENDESKTOP #POC #Citrix Studio
Several part series to implement Internet Explorer 11 Enterprise Mode
How to install and configure Citrix XenApp 6.5 - Part 1. In this video tutorial we have explained step by step installation of Citrix XenApp 6.5 Server on Windows Server 2008 R2 is explained in this video. We have explained the difference between…
This demo shows you how to set up the containerized NetScaler CPX with NetScaler Management and Analytics System in a non-routable Mesos/Marathon environment for use with Micro-Services applications.
578 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
