HELP IN SETTING UP A INTRANET WEB SISTE USING II6 .00 IN 2003 AND GIVE ACCESS TO CLIENTS
Dear sir,
we are developing asp.net application for first time. previously we are working on vb sql server. kindly guide us to setup II6 IN A WINDOWS 2003 SERVER (ICPLIT is domain name) and how to access the website (intranet site) in the XP clients.
example i want to set up my web site name as fatest.icpl. this intranet site i want to give acces only to particular set of users
thanks
vasudevan
knowvasuAsked:
Sam PanwarSr. Server AdministratorCommented:
create website and stored in the a folder
1. Create folder domains in c:\domains and then create 'fatest.icpl'  folder in the c:\domains\fatest.icpl
 After that create three folder inside the folder fatest.icpl
Following folder (i) log (ii) wwwroot (iii) db
Saved all website page in the wwwroot folder
2. IIS> website> right click > add new
3. Enter website name fatest.icpl
4. Website wwwroot folder path c:\domains\fatest.icpl\wwwroot
5. finsih
Check the Asp extension available or not
1. IIS > website extension >ASP allow extension
Website properties
1.IIS>Website>select website fatest.icpl > Homedirecotroy > you can assign thhe website ip
2. Check the website host header
Now the main configuration is dns so you can acess from the interanet
1. Start>program files>administrator tool > DNS
2. Enter website DNS record
A record and www record
http://labmice.techtarget.com/networking/dns.htm
After that on xp client enter the dns server ip like that
http://ca.huji.ac.il/helpdesk/tshoot/dns.shtml
read dns configuration zone in the following article
http://www.petri.co.il/how_to_install_active_directory_on_windows_2003.htm
http://www.simongibson.com/intranet/dns2003/
Hi ,
Trouble shooting >
ping fatest.icpl site from client computer
its ping or not
if not then problem in the dns configure
temporary you can check it from the host file so enter the following in the host file
c:\windows\driver\etc\host file open in notepad
and enter
fatest.icpl <ip of website
then try
