Solved
Problem with popup blockers - Not a systematic solution - Need help understanding it
Posted on 2006-05-28
Last Modified: 2012-05-05
Microsoft Internet Explorer popup blocker settings are a nightmare
first of all there are several zones trusted sites / internet
then on top of that add  several vendor Popup blockers.
Well I went into the manager Add-ins and disabled every thing and ofcourse it made no differnce. I enabled all the advanced options
levels and tried reseting the IE settings.
Now had Microsoft had the decency to add a sanity initializer that takes all addins out and resets IE to a sane set of defaults enabling popups etc.. that would make sense right.
Does anyone know truly how to initialize all zones and settings to a reasonable default setting because this is just plain nuts other than loading in firefox which is not a complete solution considering my wife likes using  outlook email and curses the fact the pc is now incapable of poping up screens at all regardless of the trusted sites added. I suspect some kind of  corruption in the registry but a sane setting or re-install or something should be possible to fix this nonsense. Perhaps deleting a registry entry somewhere will actually cause the program to rebuild properly because the default buttons do nothing other than loose history and cookies
The popups still are being blocked
I am sure this subject has caused much pain to all.
Microsoft needs to provide a better fix to this.
I should also mention the XP SP2 system with this problem has ZoneAlarm installed as well which was never a problem before
Oh I also get system errors like:
Event Type:      Error
Event Source:      Application Hang
Event Category:      (101)
Event ID:      1002
Date:            5/25/2006
Time:            9:59:54 PM
User:            N/A
Computer:      XP
Description:
Hanging application iexplore.exe, version 6.0.2900.2180, hang module hungapp, version 0.0.0.0, hang address 0x00000000.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Data:
0000: 41 70 70 6c 69 63 61 74   Applicat
0008: 69 6f 6e 20 48 61 6e 67   ion Hang
0010: 20 20 69 65 78 70 6c 6f     iexplo
0018: 72 65 2e 65 78 65 20 36   re.exe 6
0020: 2e 30 2e 32 39 30 30 2e   .0.2900.
0028: 32 31 38 30 20 69 6e 20   2180 in
0030: 68 75 6e 67 61 70 70 20   hungapp
0038: 30 2e 30 2e 30 2e 30 20   0.0.0.0
0040: 61 74 20 6f 66 66 73 65   at offse
0048: 74 20 30 30 30 30 30 30   t 000000
0050: 30 30                     00
I belive I tried everything possible to rebuild or reset the settings except re-installing. Something I dread doing because of the time involved.
Question by:Robert Silver
2 Comments
LVL 23
Accepted Solution
by:
Tim Holman earned 252 total points
Without reinstalling, try these for starters.  Also consider going back to an old System Restore point perhaps?
Reset TCP/IP
http://support.microsoft.com/?kbid=299357
Reset IE
On the Tools menu, click Internet Options.
Click the Programs tab.
Click the Reset Web Settings button.
Reset Winsock
http://windowsxp.mvps.org/winsock.htm
Run a half decent malware removal tool!
www.ewido.com
Assisted Solution
by:ding-dong
ding-dong earned 248 total points
To me it sounds like you got some sort of spyware on your system. If you haven't already, update zonealarm and run a scan. Try running Ad-aware with the latest definitions or/and spybot.
Spybot - http://www.download.com/Spybot-Search-Destroy/3000-8022_4-10401314.html?tag=lst-0-1
Ad-aware - http://www.download.com/3405-8022-5153545.html?part=dl-ad-aware&subj=dl&tag=top5
You could also try updating internet explorer to version 7, be warned this is still a beta. Or you could try reinstalling ie6.
http://www.microsoft.com/windows/ie/default.mspx
Also try what tim_holman said any use system restore.
 The Evil-ution of Network Security Threats
What are the hacks that forever changed the security industry? To answer that question, we created an exciting new eBook that takes you on a trip through hacking history. It explores the top hacks from the 80s to 2010s, why they mattered, and how the security industry responded.
Tech spooks aren't just for those who are tech savvy, it also happens to those of us running a business. Check out the top tech spooks for business owners.
Your business may be under attack from a silent enemy that is hard to detect. It works stealthily in the shadows to access and exploit your critical business information, sensitive confidential data and intellectual property, for commercial gain. T…
Sending a Secure fax is easy with eFax Corporate (http://www.enterprise.efax.com). First, Just open a new email message.  In the To field, type your recipient's fax number @efaxsend.com. You can even send a secure international fax — just include t…
With Secure Portal Encryption, the recipient is sent a link to their email address directing them to the email laundry delivery page. From there, the recipient will be required to enter a user name and password to enter the page. Once the recipient …
839 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
