danielgallo
XHTML body scrolling problem
In Visual Studio 2005 .NET, when creating a new ASPX page, by default it inserts the following header to the top of the page to declare it as an XHTML page.
In the BODY element, it used to be possible to add the following style attribute to disable the vertical scroll bar displayed within the web browser:
<body style="overflow: hidden;">
However, with the new XHTML header at the top of the page, Internet Explorer ignores the overflow attribute and displays the scroll bar. We can use "scroll=no" in the BODY element, but according to Visual Studio 2005 .NET this isn't a recognised attribute.
So basically the page's scroll bar IS visible with the following code:
<html xmlns="http://www.w3.org/1999/xhtml" >
<p>test</p>
</body>
</html>
And the page's scroll bar is NOT visible with the following code:
<html>
<p>test</p>
</body>
</html>
So my question is how can I hide the page's vertical scroll bar when using an XHTML compliant page?
<p>test</p>
</body>
</html>
<html>
<p>test</p>
</body>
</html>
