Solved
Hello guys, I need a help with format, I need to insert string inside another string
Posted on 2006-06-02
Last Modified: 2010-04-05
This bellow is a test, but I don't know how to make it work.
Var
  S, V1, V2 : String;
begin
  V1 := '10.10.1.10';
  V2 := 'Trator';
  S := 'Connection=%' + ' Database=%' + ' é uma boa base';
  Format('%1:S %1:S',[V1, V2]);
  ShowMessage(S)
Question by:hidrau
4 Comments
LVL 11
Accepted Solution
by:
ZhaawZ earned 800 total points
v1 := '10.10.1.10';
v2 := 'trator';
s := format('Connection=%s Database=%s é uma boa base', [v1, v2]);
showmessage(s);
LVL 5
Assisted Solution
by:Scay7
Scay7 earned 400 total points
v1 := '10.10.1.10';
v2 := 'trator';
showmessage('Connection='+v1+' Database='+v2+' é uma boa base');
peace Scay7
LVL 28
Assisted Solution
by:2266180
2266180 earned 800 total points
if you wish the result to be
Connection=10.10.1.10 Database=trator é uma boa base
then
ZhaawZ is the correct one using format function and scay7's without using format function.
also, if you construct the format string dynamically, then something like this should do it:
Var
  S, V1, V2 : String;
begin
  V1 := '10.10.1.10';
  V2 := 'Trator';
  S := 'Connection=%s' + ' Database=%s' + ' é uma boa base';// see here the change (this is constructed dynamically)
  s:=Format(s,[V1, V2]);// see here the change
  ShowMessage(S)
if you wish the outcome to be something else, then give us an example of what showmessage should show.
LVL 1
Author Comment
by:hidrau
Thanks Guys
Learn to develop an Android App
Want to increase your earning potential in 2018? Pad your resume with app building experience. Learn how with this hands-on course.
This article explains how to create forms/units independent of other forms/units object names in a delphi project. Have you ever created a form for user input in a Delphi project and then had the need to have that same form in a other Delphi proj…
In my programming career I have only very rarely run into situations where operator overloading would be of any use in my work.  Normally those situations involved math with either overly large numbers (hundreds of thousands of digits or accuracy re…
SQL Database Recovery Software repairs the MDF & NDF Files, corrupted due to hardware related issues or software related errors. Provides preview of recovered database objects and allows saving in either MSSQL, CSV, HTML or XLS format. Ensures recov…
In this video I will demonstrate how to set up Nine, which I now consider the best alternative email app to Touchdown.
Suggested Courses
588 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
