Solved
Front Pannel Audio Problem
Posted on 2006-06-10
6
Last Modified: 2010-04-25
I have a quick question about a computer problem I am having.  I think I already have the answer, but I want to be sure before I go out and spend money to correct the problem.
I built a custom computer for myself.  It has an Abit motherboard, plenty of memory, a fast Athlon X2 for Socket 939, RAID 5 and a few other things.
One day, Sound quit working in the left speaker.  I tested the speakers with my laptop and they are fine.  I also tested with headphones and found no sound out of the left speaker.  I decided to rull out drivers, so I found an old hard disk with the OS and all the drivers already on it.  I booted that and the same problem occured.
I tried the front pannel audio and it worked fine from the front of the computer.  I am using an Antec SOHO File Server Case and an ABIT KN8-SLI Motherboard.
My next step in troubleshooting was to attempt to rull out whether it was the case or the motherboard giving me the problem.  To do this, I removed the Front Pannel Audio connector from the board to remove the case.  At this point, I got no audio.  I was confused and expected to still have audio from the right speker only from the back port of the motherboard.
I decided to just save myself the hastle and replace the motherboard because I figured that is what it most likely is, since I removed the case from the picture.
Well, the back ports worked then I notice there were 2 jumpers on the Audio Ports of the new motherboard.  When I connected my cases's FP Audio, the same problem occured.  When I removed the FP Audio connector no sound again.  This lead me to belive I most likely replaced my motherboard in vain :( (a half hour wasted)  I have a leftover  motherboard though.
Anyway, I put the 2 jumpers back on and the back ports work.  This means to me that the back ports and front ports are okay, but something is funkey with the case right?  With the front pannel audio connected, I should be able to get audio out the bakc unless something is plugged into the front right?
That really is my question.  If this is the case, which I think it is, I guess I need to replace my case.
Question by:Jbirk1
  • 3
  • 3
6 Comments
LVL 93
Accepted Solution
by:
nobus earned 2000 total points
the jumpers serve to connect the left and right sound outputs to the back panel; if you want to have both, you should use a case with a split cable connection.
you can measure each sound channel pin, from the mobo plug to the front; with an ohmmeter. for the mobo plug, you can use a needle pin in it, and on the front, i just put an old plug in the jack with wires, or put a needle through the isolation into the wire itself for measuring.
>It can be a broken wire, or a broken jack (maybe replaceable)
you can also spray it with contact spray, and fiddle with the jack in it.
But yes, it is a "case " problem
LVL 3
Author Comment
by:Jbirk1
Okay, so if I replace the case, my problem should be resolved right?
LVL 93
Expert Comment
by:nobus
yes, except you'll have a split sound cable if you want to use the front and rear connectors together, like this
          _      |
Free Tool: Site Down Detector
LVL 3
Author Comment
by:Jbirk1
I just want to use one or the other.  I will replace my case.  Thanks.
LVL 3
Author Comment
by:Jbirk1
This is true.  They call it OEM XP.  I.e. Dell OEM XP cds will only work with any Dell Motherboard just about.
What this means is you simply need another XP install CD.  I .e. you need whitebox OEM meaning any OEM, the Retail Version, or the Volume Licence Agreement (VLA often called Corporate/Corp as a slang or connotation).
My preferred media is Volume Licnece, but you must purchase at the minimum of a 5 computer agreement to qualify.
LVL 93
Expert Comment
by:nobus
Take Control of Web Hosting For Your Clients
As a web developer or IT admin, successfully managing multiple client accounts can be challenging. In this webinar we will look at the tools provided by Media Temple and Plesk to make managing your clients’ hosting easier.
I use more than 1 computer in my office for various reasons. Multiple keyboards and mice take up more than just extra space, they make working a little more complicated. Using one mouse and keyboard for all of my computers makes life easier. This co…
Skype is a P2P (Peer to Peer) instant messaging and VOIP (Voice over IP) service – as well as a whole lot more.
Finding and deleting duplicate (picture) files can be a time consuming task. My wife and I, our three kids and their families all share one dilemma: Managing our pictures. Between desktops, laptops, phones, tablets, and cameras; over the last decade…
Suggested Courses
599 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
