Flash Pro 8 Problem with movie control buttons when going to 2nd scene
Hi Folks
I am having problems with my flash movie control buttons when copying them to a second scene. They work fine in the first scene but as soon as I copy them to a 2nd scene things start to go wrong. They are your normal, pause, play, ff and rewind. I am copying by using edit>timeline>copy frames. Then pasting into the new scene on a new layer. The problem is that when I come to use the test movie option in control the whole thing grinds to a halt. I have gradually worked backwards through the process and find the problem stops when I remove the actions, so I guess I have some coding error or set up error.
A sample code for the rewind button is below.
     function rewind()
     intervalr = setInterval(rewind,50)
on(release, releaseOutside)
On the one occasion it did manage to open a test screen up the buttons were doing all sorts of confusing things.
What am I doing wrong?
ProactivationConnect With a Mentor Commented:
OK, a few observations:
1. You're using scenes.  Scenes are bad.  Don't use scenes.
2. It's better practice to put your actions in a frame rather than on the button itself, like this:
function rewind() {
      _root.gotoAndStop(_root._currentframe - 5);
var interval;
myButton.onPress = function() {
      intervalr = setInterval(rewind, 50);
myButton.onRelease = function() {
3. You're setting a callback when the user's mouse button is down, and clearing it again when they release it. Are you sure you want to do this..?
