Solved
Need some help to understand a problem about DataGrid and DataTable
Posted on 2006-06-20
Last Modified: 2008-02-01
Hello. I need some help to understand an error in this code. This is all the code and it compiles in VS2005. I get problems at this comment down the code:
            // Here the problems start. !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
The problem is that DataGrid1 don't want to show any data.
<%@ Page Language="C#" AutoEventWireup="true"  CodeFile="Default.aspx.cs" Inherits="_Default" %>
<html xmlns="http://www.w3.org/1999/xhtml" >
<head runat="server">
    <title>Untitled Page</title>
</head>
<body>
    <div>
    </div>
    <asp:DataGrid ID="DataGrid1" runat="server" />&nbsp;&nbsp;<br />
        <br />
        Sheet:<br />
        <asp:DropDownList ID="DropDownList1" runat="server" Width="127px">
        </asp:DropDownList><br />
        <br />
        Range:<br />
        <asp:TextBox ID="TextBox1" runat="server" Width="82px"></asp:TextBox>
        <br />
        <br />
        Pk:<br />
        <asp:TextBox ID="TextBox2" runat="server" Width="91px"></asp:TextBox><br />
        <br />
        &nbsp;<asp:Button ID="Button2" runat="server" OnClick="Button2_Click" Text="Load" />
        <asp:TextBox ID="TextBox3" runat="server"></asp:TextBox>
        <asp:Button ID="Button1" runat="server" OnClick="Button1_Click" Text="Get" /><br />
        <br />
        Error:<br />
        <asp:Label ID="Label1" runat="server"></asp:Label>
        <br />
        <br />
        debug:<br />
        <asp:Label ID="lblDebug" runat="server" Height="89px" Text="Label" Width="310px"></asp:Label>
    </form>
</body>
</html>
using System;
using System.Data;
using System.Data.OleDb;
using System.Configuration;
using System.Drawing;
using System.Collections;
using System.ComponentModel;
using System.Web;
using System.Web.Security;
using System.Web.UI;
using System.Web.UI.WebControls;
using System.Web.UI.WebControls.WebParts;
using System.Web.UI.HtmlControls;
using utilities;
public partial class _Default : System.Web.UI.Page
    private DataTable _dt;
    private DataSet myDataSet = new DataSet();
    private string _strExcelFilename;
    private ExcelReader _exr = null;
    private int _intPKCol = -1;
    private string error ="";
    protected void Page_Load(object sender, EventArgs e)
        // dataGrid1
        this.DataGrid1.DataMember = "";
        this.DataGrid1.TabIndex = 1;
        Label1.Text = error;
        TextBox1.Text = "A1:C6";
    private void InitExcel(ref ExcelReader exr)
        //ExcelReader must be open
        if (exr == null)
            exr = new ExcelReader();
            exr.ExcelFilename = _strExcelFilename;
            exr.Headers = false;
            exr.MixedData = true;
        if (_dt == null) _dt = new DataTable("par");
        exr.KeepConnectionOpen = true;
        //Check excel sheetname is selected
        if (this.DropDownList1.SelectedIndex > -1)
            exr.SheetName = this.DropDownList1.Text;
            lblDebug.Text += this.DropDownList1.Text;
        else
            throw new Exception("Select a sheet first!");
        //Set excel sheet range
        exr.SheetRange = this.TextBox1.Text;
        lblDebug.Text += this.TextBox1.Text;
    private void RetrieveSheetnames()
        try
            this.DropDownList1.Items.Clear();
            if (_exr != null)
                _exr.Dispose();
                _exr = null;
            _exr = new ExcelReader();
            _exr.ExcelFilename = _strExcelFilename;
            _exr.Headers = false;
            _exr.MixedData = true;
            string[] sheetnames = _exr.GetExcelSheetNames();
            // Add items to the DropDownList
            for(int i = 0; i<sheetnames.Length; i++ )
                this.DropDownList1.Items.Add(sheetnames[i].ToString());
        catch (Exception ex)
            //MessageBox.Show(ex.Message, "Error", MessageBoxButtons.OK, MessageBoxIcon.Error);
            error += ex.Message + " Error ";
    private bool IsInt(string strNr)
        try
            int intNr = int.Parse(strNr);
            return true;
        catch
            return false;
    private void SetPK()
        //Cursor = Cursors.WaitCursor;
        _intPKCol = -1;
        try
            if (TextBox2.Text.Length > 0)
                if (IsInt(TextBox2.Text))
                    _intPKCol = Convert.ToInt32(TextBox2.Text);
                else
                    if (_dt.Columns.Contains(TextBox2.Text))
                        _intPKCol = _dt.Columns[TextBox2.Text].Ordinal;
                    else
                        throw new Exception("Columnname is not present in the table.!");
                if (_dt.Columns.Count <= _intPKCol)
                    _intPKCol = -1;
                    //Cursor = Cursors.Default;
                    throw new Exception("Column does not exists!");
    protected void Button1_Click(object sender, EventArgs e)
        try
            InitExcel(ref _exr);
            // Here the problems start. !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
            // It looks like the code dont want to run any longer from here. Please help me.
            _dt = _exr.GetTable();
            //this.lblGetValueData.Text = _exr.GetValue(txtCell.Text).ToString();
            DataGrid1.DataSource = _dt;
            //this.DataGrid1.DataBind();
            _exr.Close();
            _exr.Dispose();
            _exr = null;
            if (_dt != null && this.TextBox2.Text.Length > 0) SetPK();
    protected void Button2_Click(object sender, EventArgs e)
        //OpenFileDialog f = new OpenFileDialog();
        //f.Filter = "Excel files | *.xls";
        //f.InitialDirectory = Application.ExecutablePath;
        //if (f.ShowDialog() == DialogResult.OK)
            //if (f.FileName != null && f.CheckFileExists == true)
                this._strExcelFilename = "C:/tmp/Book1.xls";
                this.TextBox3.Text = _strExcelFilename;
                RetrieveSheetnames();
                if (this.DropDownList1.Items.Count > 0)
                    DropDownList1.SelectedIndex = 0;
using System;
using System.Data;
using System.Web;
namespace utilities
    /// <summary>
    /// Summary description for ExcelReader.
    /// </summary>
    public class ExcelReader : IDisposable
        #region Variables
        private int[] _PKCol;
        private bool _blnMixedData = true;
        private bool _blnHeaders = false;
        private string _strSheetName;
        private string _strSheetRange;
        private bool _blnKeepConnectionOpen = false;
        private OleDbConnection _oleConn;
        private OleDbCommand _oleCmdSelect;
        private OleDbCommand _oleCmdUpdate;
        #endregion
        #region properties
        public int[] PKCols
            get { return _PKCol; }
            set { _PKCol = value; }
        public string ColName(int intCol)
            string sColName = "";
            if (intCol < 26)
                sColName = Convert.ToString(Convert.ToChar((Convert.ToByte((char)'A') + intCol)));
            else
                int intFirst = ((int)intCol / 26);
                int intSecond = ((int)intCol % 26);
                sColName = Convert.ToString(Convert.ToByte((char)'A') + intFirst);
                sColName += Convert.ToString(Convert.ToByte((char)'A') + intSecond);
            return sColName;
        public int ColNumber(string strCol)
            strCol = strCol.ToUpper();
            int intColNumber = 0;
            if (strCol.Length > 1)
                intColNumber = Convert.ToInt16(Convert.ToByte(strCol[1]) - 65);
                intColNumber += Convert.ToInt16(Convert.ToByte(strCol[1]) - 64) * 26;
            else
                intColNumber = Convert.ToInt16(Convert.ToByte(strCol[0]) - 65);
            return intColNumber;
        public string[] GetExcelSheetNames()
            System.Data.DataTable dt = null;
            try
                if (_oleConn == null) Open();
                // Get the data table containing the schema
                dt = _oleConn.GetOleDbSchemaTable(OleDbSchemaGuid.Tables, null);
                if (dt == null)
                    return null;
                string[] excelSheets = new string[dt.Rows.Count];
                int i = 0;
                // Add the sheet name to the string array.
                foreach (DataRow row in dt.Rows)
                    string strSheetTableName = row["TABLE_NAME"].ToString();
                    excelSheets[i] = strSheetTableName.Substring(0, strSheetTableName.Length - 1);
                    i++;
                return excelSheets;
            catch (Exception)
                return null;
            finally
                // Clean up.
                if (this.KeepConnectionOpen == false)
                    this.Close();
                if (dt != null)
                    dt.Dispose();
                    dt = null;
        public string ExcelFilename
            get { return _strExcelFilename; }
            set { _strExcelFilename = value; }
        public string SheetName
            get { return _strSheetName; }
            set { _strSheetName = value; }
        public string SheetRange
            get { return _strSheetRange; }
            set
                if (value.IndexOf(":") == -1) throw new Exception("Invalid range length");
                _strSheetRange = value;
        public bool KeepConnectionOpen
            get { return _blnKeepConnectionOpen; }
            set { _blnKeepConnectionOpen = value; }
        public bool Headers
            get { return _blnHeaders; }
            set { _blnHeaders = value; }
        public bool MixedData
            get { return _blnMixedData; }
            set { _blnMixedData = value; }
        #endregion
        #region Methods
        #region Excel Connection
        private string ExcelConnectionOptions()
            string strOpts = "";
            if (this.MixedData == true)
                strOpts += "Imex=2;";
            if (this.Headers == true)
                strOpts += "HDR=Yes;";
            else
                strOpts += "HDR=No;";
            return strOpts;
        private string ExcelConnection()
            return
                @"Provider=Microsoft.Jet.OLEDB.4.0;" +
                @"Data Source=" + _strExcelFilename + ";" +
                @"Extended Properties=" + Convert.ToChar(34).ToString() +
                @"Excel 8.0;" + ExcelConnectionOptions() + Convert.ToChar(34).ToString();
        #endregion
        #region Open / Close
        public void Open()
            try
                if (_oleConn != null)
                    if (_oleConn.State == ConnectionState.Open)
                        _oleConn.Close();
                    _oleConn = null;
                if (System.IO.File.Exists(_strExcelFilename) == false)
                    throw new Exception("Excel file " + _strExcelFilename + "could not be found.");
                _oleConn = new OleDbConnection(ExcelConnection());
                _oleConn.Open();
                throw ex;
        public void Close()
                if (_oleConn.State != ConnectionState.Closed)
                    _oleConn.Close();
                _oleConn.Dispose();
                _oleConn = null;
        #endregion
        #region Command Select
        private bool SetSheetQuerySelect()
            try
                    throw new Exception("Connection is unassigned or closed.");
                if (_strSheetName.Length == 0)
                    throw new Exception("Sheetname was not assigned.");
                _oleCmdSelect = new OleDbCommand(
                    @"SELECT * FROM ["
                    + _strSheetName
                    + "$" + _strSheetRange
                    + "]", _oleConn);
                return true;
                throw ex;
        #endregion
        #region simple utilities
        private string AddWithComma(string strSource, string strAdd)
            if (strSource != "") strSource = strSource += ", ";
            return strSource + strAdd;
        private string AddWithAnd(string strSource, string strAdd)
            if (strSource != "") strSource = strSource += " and ";
        #endregion
        private OleDbDataAdapter SetSheetQueryAdapter(DataTable dt)
            // Deleting in Excel workbook is not possible
            //So this command is not defined
            try
                if (PKCols == null)
                    throw new Exception("Cannot update excel sheet with no primarykey set.");
                if (PKCols.Length < 1)
                OleDbDataAdapter oleda = new OleDbDataAdapter(_oleCmdSelect);
                string strUpdate = "";
                string strInsertPar = "";
                string strInsert = "";
                string strWhere = "";
                for (int iPK = 0; iPK < PKCols.Length; iPK++)
                    strWhere = AddWithAnd(strWhere, dt.Columns[iPK].ColumnName + "=?");
                strWhere = " Where " + strWhere;
                for (int iCol = 0; iCol < dt.Columns.Count; iCol++)
                    strInsert = AddWithComma(strInsert, dt.Columns[iCol].ColumnName);
                    strInsertPar = AddWithComma(strInsertPar, "?");
                    strUpdate = AddWithComma(strUpdate, dt.Columns[iCol].ColumnName) + "=?";
                string strTable = "[" + this.SheetName + "$" + this.SheetRange + "]";
                strInsert = "INSERT INTO " + strTable + "(" + strInsert + ") Values (" + strInsertPar + ")";
                strUpdate = "Update " + strTable + " Set " + strUpdate + strWhere;
                oleda.InsertCommand = new OleDbCommand(strInsert, _oleConn);
                oleda.UpdateCommand = new OleDbCommand(strUpdate, _oleConn);
                OleDbParameter oleParIns = null;
                OleDbParameter oleParUpd = null;
                    oleParIns = new OleDbParameter("?", dt.Columns[iCol].DataType.ToString());
                    oleParUpd = new OleDbParameter("?", dt.Columns[iCol].DataType.ToString());
                    oleParIns.SourceColumn = dt.Columns[iCol].ColumnName;
                    oleParUpd.SourceColumn = dt.Columns[iCol].ColumnName;
                    oleda.InsertCommand.Parameters.Add(oleParIns);
                    oleda.UpdateCommand.Parameters.Add(oleParUpd);
                    oleParIns = null;
                    oleParUpd = null;
                    oleParUpd = new OleDbParameter("?", dt.Columns[iPK].DataType.ToString());
                    oleParUpd.SourceColumn = dt.Columns[iPK].ColumnName;
                    oleParUpd.SourceVersion = DataRowVersion.Original;
                return oleda;
                throw ex;
        #region command Singe Value Update
        private bool SetSheetQuerySingelValUpdate(string strVal)
            try
                _oleCmdUpdate = new OleDbCommand(
                    @" Update ["
                    + _strSheetName
                    + "] set F1=" + strVal, _oleConn);
                return true;
                throw ex;
        #endregion
        public void SetPrimaryKey(int intCol)
            _PKCol = new int[1] { intCol };
        public DataTable GetTable()
            return GetTable("ExcelTable");
        private void SetPrimaryKey(DataTable dt)
            try
                if (PKCols != null)
                    //set the primary key
                    if (PKCols.Length > 0)
                        DataColumn[] dc;
                        dc = new DataColumn[PKCols.Length];
                        for (int i = 0; i < PKCols.Length; i++)
                            dc[i] = dt.Columns[PKCols[i]];
                        dt.PrimaryKey = dc;
                throw ex;
        public DataTable GetTable(string strTableName)
            try
                //Open and query
                if (_oleConn.State != ConnectionState.Open)
                    throw new Exception("Connection cannot open error.");
                if (SetSheetQuerySelect() == false) return null;
                //Fill table
                OleDbDataAdapter oleAdapter = new OleDbDataAdapter();
                oleAdapter.SelectCommand = _oleCmdSelect;
                DataTable dt = new DataTable(strTableName);
                oleAdapter.FillSchema(dt, SchemaType.Source);
                oleAdapter.Fill(dt);
                if (this.Headers == false)
                    if (_strSheetRange.IndexOf(":") > 0)
                        string FirstCol = _strSheetRange.Substring(0, _strSheetRange.IndexOf(":") - 1);
                        int intCol = this.ColNumber(FirstCol);
                        for (int intI = 0; intI < dt.Columns.Count; intI++)
                            dt.Columns[intI].Caption = ColName(intCol + intI);
                SetPrimaryKey(dt);
                //Cannot delete rows in Excel workbook
                dt.DefaultView.AllowDelete = false;
                //Clean up
                _oleCmdSelect.Dispose();
                _oleCmdSelect = null;
                oleAdapter.Dispose();
                oleAdapter = null;
                if (KeepConnectionOpen == false) Close();
                return dt;
                throw ex;
        private void CheckPKExists(DataTable dt)
            if (dt.PrimaryKey.Length == 0)
                if (this.PKCols != null)
                    SetPrimaryKey(dt);
                else
                    throw new Exception("Provide an primary key to the datatable");
        public DataTable SetTable(DataTable dt)
            try
                DataTable dtChanges = dt.GetChanges();
                if (dtChanges == null) throw new Exception("There are no changes to be saved!");
                CheckPKExists(dt);
                //Open and query
                //Fill table
                OleDbDataAdapter oleAdapter = SetSheetQueryAdapter(dtChanges);
                oleAdapter.Update(dtChanges);
                //Clean up
                oleAdapter = null;
                return dt;
                throw ex;
        #region Get/Set Single Value
        public void SetSingleCellRange(string strCell)
            _strSheetRange = strCell + ":" + strCell;
        public object GetValue(string strCell)
            SetSingleCellRange(strCell);
            object objValue = null;
            //Open and query
                throw new Exception("Connection is not open error.");
            objValue = _oleCmdSelect.ExecuteScalar();
            return objValue;
        public void SetValue(string strCell, object objValue)
            try
                //Open and query
                if (SetSheetQuerySingelValUpdate(objValue.ToString()) == false) return;
                objValue = _oleCmdUpdate.ExecuteNonQuery();
                _oleCmdUpdate.Dispose();
                _oleCmdUpdate = null;
                throw ex;
            finally
                if (_oleCmdUpdate != null)
        #endregion
        #endregion
        public
        #region Dispose / Destructor
 void Dispose()
                _oleConn.Dispose();
                _oleConn = null;
            if (_oleCmdSelect != null)
            // Dispose of remaining objects.
        #endregion
        #region CTOR
        public ExcelReader()
            // TODO: Add constructor logic here
        #endregion
Question by:m-jansen
  • 2
3 Comments
LVL 7
Accepted Solution
by:
whityum earned 250 total points
you commented out the DataBind(), therefore it never binds to the data, remove the //
Author Comment
by:m-jansen
Sorry. I have now removed the // there, but I can still not see any data
Author Comment
by:m-jansen
I figured it out by my self. This solved my problem.
        // dataGrid1
        this.TextBox3.Text = "C:/tmp/Book1.xls";
        _strExcelFilename = this.TextBox3.Text;
        if (System.IO.File.Exists(this.TextBox3.Text))
ScreenConnect 6.0 Free Trial
At ScreenConnect, partner feedback doesn't fall on deaf ears. We collected partner suggestions off of their virtual wish list and transformed them into one game-changing release: ScreenConnect 6.0. Explore all of the extras and enhancements for yourself!
In this Article, I will provide a few tips in problem and solution manner. Opening an ASPX page in Visual studio 2003 is very slow. To make it fast, please do follow below steps:   Open the Solution/Project. Right click the ASPX file to b…
International Data Corporation (IDC) prognosticates that before the current the year gets over disbursing on IT framework products to be sent in cloud environs will be $37.1B.
This Micro Tutorial demonstrates using Microsoft Excel pivot tables, how to reverse engineer competitors' marketing strategies through backlinks.
777 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
