weird hard drive problem leads to system reboot
Recently, I have been having some problems with my hard drive.(I think) I often hear a click sound, then I can heard the plates in the hard drive start to spin up, after that, my computer would freeze for 4-5 seconds then everything back to normal, usually. However, sometimes, it repeats the click sound->sound of spinning plate->freeze process for 3-5 times, then I get a system reboot eventually. I would like to know if this is the hard drive's problem, and if there is any easy fix to it.
UltimateApocalypse
UltimateApocalypse
  • 2
abarneslouorthoCommented:
could be a variety of things...
1. Virus maxing out memory and/or processor for a little bit of time- run a virus scan to make sure you're virus free
2. Adware/Spyware memory hogging-obviously, run a spyware/adware removal tool.  microsoft has a free effective one available from their website
3. Too many processes running at once-do a ctrl+alt+del and see under the processes tab what exactly is going on in your machine.  if you see something using a lot of cpu and you dont know what it is, that is most likely your problem.
Essentialy, I'm saying that if its not some program hogging your processor/memory, you most likely are experiencing the beginning of the death of your HD.  After trying the above three ideas, i would suggest making a full backup of your drive, and then buying a new hd.  They're getting cheaper and cheaper all the time.  a good 120 will run you about 60.
UltimateApocalypseAuthor Commented:
I just start to get blue screen with some error message. But it goes away too fast before I could write it down. I have used SpyBot Search & Destroy, Norton Antivirus to search for spyware and virus, both turn out negative. The reboot only happens when I am running some heavy software application where a lot of reading and writing to to the page file is required.
I guess it is most likely that my hard drive is getting close to its end?
This is the most probable solution... sorry
SMB Security Just Got a Layer Stronger
WatchGuard acquires Percipient Networks to extend protection to the DNS layer, further increasing the value of Total Security Suite.  Learn more about what this means for you and how you can improve your security with WatchGuard today!
  • 2
