Start Free TrialLog in
Avatar of adonaicomputers
adonaicomputers
Slow wireless speed and connection loss with full strength signal
I have a laptop with an Intel PRO/Wireless 2200BG wireless card and I'm trying to connect to our network.  We have a Linksys WRT54GS V.2 router and a Linksys WAP54G V.1 access point acting as a repeater.  I can view our wireless network and I am using 128 WEP encryption.  I get 54mpbs speed and Excellent signal strength.  Internet access is relatively quick at times but more than often I get kicked off or I experience extreme latency.  I thought it might be our ISP but there have been times when I have gotten a reply over 3000ms when pinging our router.  I experience the same thing regardless of the distance away from the wireless router or the access point.  I sometimes can view the network and try to connect to it and it'll say "Waiting for the network..." but I cannot connect even with Excellent signal strength and 54mbps speed.  DHCP is enabled on the router and a wired connection works with no problems.  I have also updated all drivers and firmware for all hardware.
Does anyone have ideas on what I can do to improve my connection on this wireless network?
Avatar of ChrisMacleod
ChrisMacleod
adonaicomputers
We are on channel 6.  There are quite a few networks around this area.  Other channels are 1, 6, 9, 11 right now but I know at different areas of our house there are more networks.  I changed the channel on our router and AP to 7.  The connection seems a bit steadier and I ping the router with16ms while another laptop beside me gets 1-2ms.  The other laptop pings my computer at 800-3500ms.  The connection seems a lot steadier now but another computer downstairs receives full bars when viewing wireless networks but will still say "Waiting for the network..." and never connect.
Any other ideas?
And although the connection is a lot steadier now, the connection seems slow; especially compared to another laptop right next to me.
Each channel actually works on a range of frequencys and they overlap checkout the site below.
http://www.qsl.net/n9zia/dsss-channels.html
You need to find a clear channel which is most likely going to be 1, 6 or 11.  May not be possible by the sounds of it in your case.
I am now on channel 3 and it looks like connections are a lot steadier.  I also changed a few network card settings on the other computer in the basement and it is now connected fine.  The connection is fairly fast and 1ms ping from the router.  I am even closer to an access point with this laptop but still only get a ping of around 20ms from the router and the connection seems relatively slow compared the the computer in the basement.  A laptop with the same wireless card right beside me gets a low ping from the router around 2ms.
Avatar of Steve Knight
Steve Knight
I went into the wireless card settings and some settings were not the default value.  Once I used the default values I was getting a ping of 1ms from the router.  The wireless connection here is also now a lot more stable because of using a different channel.  Thank you everyone for all of your help, I appreciate it.
I also realized that the lower my battery power was, the lower my connection speed was too.  I was trying all of this with less than 50% battery power which was why I was getting 16ms ping.  When I plugged in my power adapter I received 1ms immediately.  Thanks again for everyone's help.
