Problem executing shell script for mysql connection
I have written the following .sh script to upload several .txt files to mysql dbase. The problem is that it will not execute the commands. When I type each of these seperately in my ssh client it works perfectly. I need to automate this script though so that I can create a cron to run every night...
Thanks so much for your help
#!/bin/bash
mysql --local-infile --host=db162.perfora.net  --user=dbo116102287 --password=wavechaser db116102287
LOAD DATA LOCAL INFILE  '/kunden/homepages/23/d116101914/htdocs/web/mls/data/listings-vacant\ land.txt' INTO TABLE  `temp_listing` FIELDS TERMINATED BY  '\t' ENCLOSED BY  '\"' ESCAPED BY  '\\' LINES TERMINATED BY  '\r\n'
LOAD DATA LOCAL INFILE  '/kunden/homepages/23/d116101914/htdocs/web/mls/data/listings-fractional\ interest.txt' INTO TABLE  `temp_listing` FIELDS TERMINATED BY  '\t' ENCLOSED BY  '\"' ESCAPED BY  '\\' LINES TERMINATED BY  '\r\n';
LOAD DATA LOCAL INFILE  '/kunden/homepages/23/d116101914/htdocs/web/mls/data/listings-multi\ unit.txt' INTO TABLE  `temp_listing` FIELDS TERMINATED BY  '\t' ENCLOSED BY  '\"' ESCAPED BY  '\\' LINES TERMINATED BY  '\r\n';
LOAD DATA LOCAL INFILE  '/kunden/homepages/23/d116101914/htdocs/web/mls/data/listings-single\ family.txt' INTO TABLE  `temp_listing` FIELDS TERMINATED BY  '\t' ENCLOSED BY  '\"' ESCAPED BY  '\\' LINES TERMINATED BY  '\r\n';
LOAD DATA LOCAL INFILE  '/kunden/homepages/23/d116101914/htdocs/web/mls/data/listings-commercial.txt' INTO TABLE  `temp_listing` FIELDS TERMINATED BY  '\t' ENCLOSED BY  '\"' ESCAPED BY  '\\' LINES TERMINATED BY  '\r\n';
LOAD DATA LOCAL INFILE  '/kunden/homepages/23/d116101914/htdocs/web/mls/data/listings-condominium.txt' INTO TABLE  `temp_listing` FIELDS TERMINATED BY  '\t' ENCLOSED BY  '\"' ESCAPED BY  '\\' LINES TERMINATED BY  '\r\n';
exit
mtnwaveAsked:
slyongConnect With a Mentor Commented:
Hi Nate,
How about putting all the LOAD statements into a file (let's call it load.txt).  Then in your bash script:
#!/bin/bash
mysql --local-infile --host=db162.perfora.net  --user=dbo116102287 --password=wavechaser db116102287 < load.txt
or try
#!/bin/bash
mysql --local-infile --host=db162.perfora.net  --user=dbo116102287 --password=wavechaser db116102287 << EOF
EOF
ahoffmannCommented:
>  \t
do you expect a TAB character there?
If you want to pass a \t literal, you have to use \\t , same applies to \\r and \\n.
mtnwaveAuthor Commented:
Tab Character
My problem has more to do with the shell script running. When I load it in terminal (mac) it starts a mysql session but does not execute the LOAD DATA... commands.
Any  thoughts?
Nate
A proven path to a career in data science
At Springboard, we know how to get you a job in data science. With Springboard’s Data Science Career Track, you’ll master data science  with a curriculum built by industry experts. You’ll work on real projects, and get 1-on-1 mentorship from a data scientist.
slyongCommented:
Sorry just noticed that the first line of your LOAD statement doesn't have ";" at the end.
Thanks Sly
I'l give this a try tomorrow as it is late here! This looks like a pretty good option though!
Nate
slyongCommented:
Hey,
call me sl or yong.. sly is a bit umm.. :D.  Have a good night!
Yong;
No worries!
Nate
ahoffmannCommented:
good eyes slyong, missed that the SQL commands are executed in mysql's interactive mode
mtnwave , either follow slyong's suggestion using a script for your SQL commands, or prepend the mysql call to each of your SQL commands
Duncan RoeSoftware DeveloperCommented:
Hi mtnwave,
When you say it doesn't run., does it actually start mysql at all? The PATH (where to look for commands) is very short in a CRON job. In your interactive session, type "env" - you'll see lots of stuff. "env" in a CRON job shows maybe 6 lines. You can set up necessary env items with the "export" bash builtin - type "help export" for a short description.
Duncan ;
It starts a mysql sessionbut nothing more. I've not even set a cron yet as the script will not work.
I am just geting up after working on non related issues 'till 2 AM.  Heh
I am going to  take a look at this is a bit. It could be the ':' on line 3 but I think that this was just a typo as I had tried around 25 iterations of the script to make it work. Typos have brought me down in the past though!
You guys are terrific by the way.
Nate
ahoffmannCommented:
> .. as the script will not work.
did you follow the suggestions?
Your posted script is a mix of SQL and shell syntax. You either need to separate them, or use plain shell syntax as already explained.
> .. It could be the ':' on line 3 ..
there is no : in your posted script
bryanlloydharrisCommented:
what about:
echo -en "mysql comands\t with\t\t tabs\n" | mysql --etc. --etc. --etc.
I think maybe the tabs would work like that, it's very similar to yong's answer above with the << EOF thing.
Hi I am back...Thanks for the ideas, I was working on another aspect of the project and am only now returning to this problem.
I used slylong' s solution that seperated the scripts. Appreciate the help!
Nate
