Solved
To Hear Audio Tone When Press Shift Lock
Posted on 2006-07-18
9
Last Modified: 2010-08-05
I want to hear an audio tone when I press Shift Lock. I have followed the directions under Accessibility Options in Control panel. I have turned on the Togglekey on the Keyboard tab and I have saved the Settings. I still do not hear an audio tone when I press Shift lock. I have checked Volume Control and every thing there is working properly.
Any suggestions?
Question by:jimtheo
  • 4
  • 3
  • 2
9 Comments
LVL 70
Expert Comment
by:Merete
You may need to use a multi media keyboard or or one that has an install disc and provides a program that will associate keys from your keyboard to sounds and your vol.
What keyboard do you have there, if you need help it pays to provide information about the device as well not just the problem.
What windows xp pro home sp2?
LVL 24
Expert Comment
by:Kenneniah
Toggle Keys does not use your sound card. It uses the PC speaker.
Not all computers anymore have a pc speaker attached. Does your motherboard have a built in mini speaker, or is there a speaker in your computer case that connects with a cable to the motherboard?
If so, if you go to Device Manager, hit View|Show hidden devices, and then look in Non-Plug and Play Drivers, is "Beep" listed and is it enabled?
LVL 24
Expert Comment
by:Kenneniah
Also, you might have an option in your Volume controls for PC Speaker.
If when you open up Volume Control, you don't see PC Speaker listed, try going to Options and hit Properties.
With Playback selected, look through the list below and if it's exists, make sure there's a check in the box next to PC Speaker and hit OK.
You should then be able to unmute PC Speaker.
We value your feedback.
Author Comment
by:jimtheo
Reply to Kenneniah:
I do have an external speaker that is connected to the computer case with a cable. I followed your suggestion about Device Manager and did find Beep listed and enabled.
I did find PC Speaker, as you suggested, and did check the box next to it and hit OK. Still no sound when I hit Caps Lock or Num Lock.
I don't know why I'm having such a problem. My previous computer was a Dell with Win XP Home, SP2 and got the beep when I hit Caps Lock.
I just got this Cisnet computer last month,. XP home SP2 and can't get the beep.
I hate going along typing and then finding that I'm typing all caps.
Author Comment
by:jimtheo
aDDITIONAL rEPLY:
I have followed these instructions from Worldstart::
"Caps Lock Trick
Don't you hate it when you accidentally hit the Caps Lock key? Sometimes I have a whole sentence typed in before I realize my mistake! (I know, GASP!)
What if you could set your computer up so it alerts you when your pinky finger wanders off and taps the Caps Lock key? With this tip, I'll show you how to make your computer beep & flash the next time it happens.
The first thing you'll need to do is get the computer to beep when you hit the Caps Lock key. Here's how:
1. Click the Start button, Settings, Control Panel (XP Users, hit the Start button, Control Panel). Open the Accessibility Options Icon.
2. On the Keyboard tab, click the "Use Toggle Keys" checkbox.
That's it for the beeping part.
Next, we need to get your screen to flash you, err, flash at you. Here's how:
1. From the Accessibility Options screen, click the Sound tab and check the "Use SoundSentry" checkbox.
2. Next click the Settings button and select "Flash active window" from the "Warning for windowed programs" drop down box.
That's it. Hit OK until you're clear of property and settings screens. Open your favorite word processor and hit your Caps Lock key.
Cool huh?"
End of quote.
The interesting thing is that I can get the flash but not the beep.
Jim Theo
LVL 70
Expert Comment
by:Merete
:D worse you spend hours typing hit the  send and EE loses connection, :0 or you close the wrong page.
LVL 24
Accepted Solution
by:
Kenneniah earned 500 total points
"I do have an external speaker that is connected to the computer case with a cable"
The sound from Toggle Keys comes only from the PC Speaker, an external speaker plugged into a sound card woud not get it. More than likely, I'm guessing your computer just doesn't have an internal PC Speaker. Normally this would be a speaker inside your computer case, with a cable that goes to the motherboard. Some motherboards have a little speaker soldered to the board itself, but not all. So it just sounds like your computer doesn't have an internal speaker. I do ocassinally run into some that don't :(
Author Comment
by:jimtheo
To Kenneniah:
How can I find out if my computer has an internal PC speaker.
LVL 24
Expert Comment
by:Kenneniah
It could have one of two different types.
A case speaker looks like.....
http://www.mycableshop.com/sku/PCCASESPEAKER.htm
The 4 pin cable from it connects to 4 pins on your mothboard.
The other possibility would be a piezo type speaker soldered to the motherboard itself. Look at the first picture found at....
http://www.guru3d.com/article/mainboard/203/2/
Along the very top of the motherboard in that picture, you'll see the blue IDE connector. Just to the right of that is an built-in piezo speaker (the round black thing with a little hole in the top).
The only way to see if you have one, is to open the case and look for either type. If one does exist, it might no longer be working.
[Webinar On Demand] Database Backup and Recovery
Does your company store data on premises, off site, in the cloud, or a combination of these? If you answered “yes”, you need a data backup recovery plan that fits each and every platform. Watch now as as Percona teaches us how to build agile data backup recovery plan.
It is only natural that we all want our PCs to be in good working order, improved system performance, so that is exactly how programs are advertised to entice. They say things like:            •      PC crashes? Get registry cleaner to repair it!    …
When you start your Windows 10 PC and got an "Operating system not found" error or just saw  "Auto repair for startup" or a blinking cursor with black screen. A loop for Auto repair will start but fix nothing.  You will be panic as there are no back…
Two types of users will appreciate AOMEI Backupper Pro: 1 - Those with PCIe drives (and haven't found cloning software that works on them). 2 - Those who want a fast clone of their boot drive (no re-boots needed) and it can clone your drive wh…
As many of you are aware about Scanpst.exe utility which is owned by Microsoft itself to repair inaccessible or damaged PST files, but the question is do you really think Scanpst.exe is capable to repair all sorts of PST related corruption issues?
Suggested Courses
Course of the Month14 days, 20 hours left to enroll
578 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
