FTP connection problem 530 SSL required
I have setup my FTP on my PC, i am using the FileZilla server.
When i try to connect to the FTP server i am able to get the welcome message that i have setup, once i try to log in using my username it says:
530 SSL required
Login Failed
I have generated SSL certificate but i am not sure about the config
joy333
joy333
  • 4
  • 2
fm250Commented:
did you download the client:
http://sourceforge.net/project/showfiles.php?group_id=21558&package_id=15149
if you are using different client it may not work if that client doesn't support the sftp
hope this helps!
bbrunningCommented:
Try logging into the ftp from the machine the server is installed on and see if you get the same error. You shouldn't need SSL for logon to FTP servers. Error 530 generally means the authentication failed with the username and password you supplied. It tells you SSL required because it looks for another way to login and you don't have a login cert.
Don't generate the SSL, it's just more trouble if you don't know what you are doing.
Double check yur username and password again or create a new one and make sure your CAPS lock is not on.
joy333Author Commented:
i am trying from windows dos command prompt
Improve Your Query Performance Tuning
In this FREE six-day email course, you'll learn from Janis Griffin, Database Performance Evangelist. She'll teach 12 steps that you can use to optimize your queries as much as possible and see measurable results in your work. Get started today!
once i type username and hit enter
then i get those errors and in server log it shows that same error.
bbrunning i have disabled the SSL/TLS support, now it looks it is accepting the username and password, but getting "could not get the home directory" i could find any option to create the home directory on the FileZilla application
On the main menu bar i can see two menu options marked with  /C/  and C:\ but i am not sure what is it? how to setup the home dir?
"i could find any option to create the home directory on the FileZilla application"
sorry i mean "i couldn't find"
bbrunningCommented:
To add a directory you have to add a custom user, which I'd imagine you have already done. Then click on the icon at the top bar that has a picture of a persons head. In there click shared folders, then click add. Add the directory of your choice, then you can click add under users and associate a user with that account.
Join & Write a Comment
Network Scalability - Handle Complex Environments
Monitor your entire network from a single platform. Free 30 Day Trial Now!
  • 4
  • 2
