We've partnered with Certified Experts, Carl Webster and Richard Faulkner, to bring you two Citrix podcasts. Learn about 2020 trends and get answers to your biggest Citrix questions!Listen Now
Using Active directory Recovery Mode to Fix Problems
SlyPrince
SlyPrince asked
on
Last Modified: 2008-02-26
My Windwos 2000 Server will not boot normally because the AD services will not start.  Guidance that I have found suggests booting into Active Directory Recovery Mode.  I have done that, but now what?  The server is a DC has has the latest service pack.  I have used a different DC on the same domain to seize FSMO roles, so my users cand still connect, but I still need to get this server booting normally with active directory services running?  Can anyone help?
Watch Question
Hi SlyPrince,
If you have seized the roles on another server, you can't bring the old server back into the domain - you will need to reinstall windows again.
How can I forcibly transfer (seize) some or all of the FSMO Roles from one DC to another?
http://www.petri.co.il/seizing_fsmo_roles.htm
Windows 2000 Active Directory FSMO roles
http://support.microsoft.com/kb/197132
Flexible Single Master Operation Transfer and Seizure Process
http://support.microsoft.com/kb/223787
Hope that helps,
-red
 Thank you Red.  That is an answer I kind of expected, but hoped not to hear.  I can rebuild the server, but the Active Directory Database will think that the "old" server still exists.  Can I clean up the database and reinstall the server with the same name as before?  I want to use the same name because there are many users and shares at steak on the faulty server.  As I rebuild it, I need to avoid any conflect with old information is the AD database.
Sorry to be the bearer of bad news :)
You can manually rip out a dead server - Daniel Petri has been good enough to detail this here -> http://www.petri.co.il/delete_failed_dcs_from_ad.htm
I would recommend you do not use the same name, but instead use a DNS alias (then your shares will still work).
That isn't to say that the old name won't work (or that using a new name and a DNS alias is perfect) but it can be a right pain to troubleshoot.
Good luck
-red
Ask the Experts
OR
Please enter a first name
Please enter a last name
