We've partnered with Certified Experts, Carl Webster and Richard Faulkner, to bring you two Citrix podcasts. Learn about 2020 trends and get answers to your biggest Citrix questions!Listen Now
Difference between Imports System.Configuration vs. Adding Reference with System.configuration.dll
coson
coson asked
on
Last Modified: 2010-04-24
Good Day,
I'm working with VB.NET 2005 and I was attempting to access the ConfigurationManager Class.  When I looked at the documentation, it says that the namespace needed is System.Configuration.
Beautiful.
But my code wouldn't compile and I couldn't figure out what I was doing wrong.
Someone suggested that I add the .DLL as a reference to my project and everything now works.
So my question is, What is the difference between the two?  I thought if I included the Imports System.Configuration namespace, that I would have access to allthe classes under the System.Configuration namespace.  If that's the case, why would I need the DLL?
I've only offered 50 points, so if the answer is detailed, I'll raise the point level.
coson
Watch Question
from what i understand, the namespaces reside on the dll's, or projects. If you import the System.Xml namespace, you will find that it also adds a reference to System.Xml dll, since they are not mutually exclusive but, au contraire, they are the same thing.
Namespaces on the imports statement do not add the reference per se, what they do is just to allow you to use the classes inside the dll without all the name like System.Xml.DoMethod1(), and just use DoMethod1() instead.
In cases where 2 methods are named the same in various dll's, you will still need to reference using the full name to avoid confusions.
hope it helps
NY
in summary, if you want to use classes that reside in a dll, you need to add a reference to it. if you want to call them up in your code without using the full name to call it, import the namespace.
Ask the Experts
in that order.
Fernando SotoRetired
Distinguished Expert 2017
From the Microsoft documentation
Assemblies include one or more namespaces. When you add a reference to an assembly, you can also add an Imports statement to a module that controls the visibility of that assembly's namespaces within the module. The Imports statement provides a scoping context that lets you use only the portion of the namespace necessary to supply a unique reference.
http://msdn2.microsoft.com/en-us/library/h9st4tss.aspx
Fernando
Mohamed ZedanSenior IT Analyst
Ok..
the difference is that the imports statement is used to shorten the length of code you type (i.e. the namespace name) let's say you are using regularexpressions... the classes are located at System.Text.RegularExpressions
so if you declare a variable of type regex
Dim aa As System.Text.RegularExpressions.Regex
and the options would be like this System.Text.RegularExpressions.RegexOptions
if you add imports System.Text.RegularExpressions
then it is shortened to
Dim aa As regex
and the options would be like this RegexOptions
but you must add the reference to the dll to be able to import the namespaces and access its internal types.
so imports is only to ease the work but the references are necessary to use the dlls...
you could see the default imports... if you click on the project menu then project propertied you'll find the default imports in the tree item imports of Common properties in the tree on the left
I still don't get it.  I added the "Imports System.Configuration" statement at the top of the module, and coded "strDBLocation = ConfigurationManager.AppSettings("DBLocation")" and got "ConfigurationManager is not declared" as an error.  So... what are the EXACT statements for the Imports statements, and the EXACT code to reference the proper class and method to extract a value from the web.config file?  Apparently, there is no "ConfigurationManager" in System.Configuration, or I have no reference to it yet.  Do you have a code sample that shows how to get a dbconnection string in VB.Net 2005 that will syntax properly?  If there are other steps outside code, can I also get detail steps to perform them?
OR
Please enter a first name
Please enter a last name
