We've partnered with Certified Experts, Carl Webster and Richard Faulkner, to bring you two Citrix podcasts. Learn about 2020 trends and get answers to your biggest Citrix questions!Listen Now
Operator '=' is not defined for types 'System.Object' and 'System.Guid'.
David_Reid_1985
on
Last Modified: 2008-01-09
Can anyone advise how I should be doing this in vb.Net 2003?
The line of code I'm trying to run is:
   SQLCommand.Parameters.Add(New VistaDB.VistaDBParameter("@ID", VistaDB.VistaDBType.Guid).Value = myGuid)
myGuis is of type System.GUID whereas the parameter wants an object? I thought this would be ok?
Please help!!
Watch Question
You need to convert myGuid to String
e.g.  SQLCommand.Parameters.Add(New VistaDB.VistaDBParameter("@ID", VistaDB.VistaDBType.Guid).Value = myGuid.ToString())
Apologies, I should have mentioned, already tried that... I now receive:
"Specified cast is not valid."
Any ideas?
You could try
SQLCommand.Parameters.Add(New VistaDB.VistaDBParameter("@ID", VistaDB.VistaDBType.Guid, myGuid.ToString())
Forget a bracket
SQLCommand.Parameters.Add(New VistaDB.VistaDBParameter("@ID", VistaDB.VistaDBType.Guid, myGuid.ToString()))
I'm close to telling you just to do it on two lines :-), but:
What if you try
SQLCommand.Parameters.Add(New VistaDB.VistaDBParameter("@ID", VistaDB.VistaDBType.Guid).Value = ctype(myGuid,object))
Senior Systems and Integration Developer
The location of your brackets is causing the problem:
    SQLCommand.Parameters.Add(New VistaDB.VistaDBParameter("@ID", VistaDB.VistaDBType.Guid)).Value = myGuid
Ask the Experts
Gawwd its been one of those days!!! Thanks very much :D:D:D:D
OR
Please enter a first name
Please enter a last name
