php array copying problem... maybe reference problem
The code below works great, except when i execute this line $jobnames[$jobnamelist[$i][$j]][$key1][2][] = $filelist[$file_key];
I can print the array and it has all the values in it.
however the next loop that array that I had copied into $jobnames[$jobnamelist[$i][$j]][$key1][2] is not there.
It like disappears.
The print statements is below the code
// loops over job numbers
   for($i = 0; $i < count($joblist); $i++)
     $check1 = 1;
     // loops over job names for the job number
     for($j = 0; $j < count($jobnamelist[$i]); $j++)
        // loops over each
           $check2 = 1;
           foreach ($jobnames[$jobnamelist[$i][$j]] as $key1=>$filearray)
              $matchcount = 0;
              foreach ($filelist as $file_key=>$filestats)
                 $jobnames[$jobnamelist[$i][$j]][$key1][2] =  array();
                 $tmpfile = str_replace( "*", ".*", str_replace(".", "\\.", $filearray[0]));
                 if(preg_match("/" . $tmpfile . "/", $filestats[0]))
                    echo '<br>FOUND##### '.$tmpfile.'<br>';
                    $matchcount++;
              if($matchcount < $filearray[1])
                 $check2 = 0;
           if($check2 == 1)
             $jobnamecolor[$i][$j] = "good";
           else
             $check1 = 0;
     if($check1 == 1)
        $jobcolor[$i][$j] = "good";
this is the first iteration I have marked the inserted array with &&&&&&&&&&&&&&
Array
    [job_accounting_reference_tables] => Array
            [0] => Array
                    [0] => sku_retail_prices*.csv
                    [1] => 1
                    [2] => Array
                            [0] => Array
                                    [0] => sku_retail_prices_20061031.csv      &&&&&&&&&&&&&&&&&&
                                    [1] => 1905                                            &&&&&&&&&&&&&&&&&&
                                    [2] => 11/02/2006 16:31                         &&&&&&&&&&&&&&&&&&
            [1] => Array
                    [0] => pia_activation*.csv
                    [1] => 1
            [2] => Array
                    [0] => pia_rate_plans*.csv
                    [1] => 1
            [3] => Array
                    [0] => service_billing_sched_category_lookup*.csv
                    [1] => 1
            [4] => Array
                    [0] => eom033*.txt
                    [1] => 1
            [5] => Array
                    [0] => adj_code_category_lookup*.csv
                    [1] => 1
            [6] => Array
                    [0] => market_lookup*.csv
                    [1] => 1
    [job_apl_revenue_sharing] => Array
            [0] => Array
                    [0] => apl_revenue_sharing_ace*.csv
                    [1] => 1
            [1] => Array
                    [0] => apl_revenue_sharing_qpay*.csv
                    [1] => 1
            [2] => Array
                    [0] => apl_revenue_sharing_tio*.csv
                    [1] => 1
            [3] => Array
                    [0] => apl_revenue_sharing_infotouch_retail*.csv
                    [1] => 1
            [4] => Array
                    [0] => apl_revenue_sharing_firstech*.csv
                    [1] => 1
            [5] => Array
                    [0] => apl_revenue_sharing_infotouch_nonretail*.csv
                    [1] => 1
    [job_biapia_daily_payments] => Array
            [0] => Array
                    [0] => BIAPIA_SERVICE_REVENUE_*.csv
                    [1] => 31
    [job_brightpoint_tables] => Array
            [0] => Array
                    [0] => handset_allocation*.csv
                    [1] => 1
            [1] => Array
                    [0] => market_state_city_lookup*.csv
                    [1] => 1
            [2] => Array
                    [0] => bp_ar_rollforward_cm*.csv
                    [1] => 1
            [3] => Array
                    [0] => bp_ar_rollforward_sales*.csv
                    [1] => 1
    [job_cost_layer_load] => Array
            [0] => Array
                    [0] => cost_layer*.csv
                    [1] => 1
    [job_daily_holoads] => Array
            [0] => Array
                    [0] => bil001*.csv
                    [1] => 28
            [1] => Array
                    [0] => cyc002*.csv
                    [1] => 28
            [2] => Array
                    [0] => ivprch*.csv
                    [1] => 31
            [3] => Array
                    [0] => cyc01515*.csv
                    [1] => 28
    [job_indirect_dealer_compensation] => Array
            [0] => Array
                    [0] => 3001_actuals*.csv
                    [1] => 1
            [1] => Array
                    [0] => 3006_commissions_accrual*.csv
                    [1] => 1
            [2] => Array
                    [0] => 3008_adjustments*.csv
                    [1] => 1
            [3] => Array
                    [0] => 3005_coop_accrual*.csv
                    [1] => 1
            [4] => Array
                    [0] => 3003_expirations*.csv
                    [1] => 1
    [job_inv_dependent_files] => Array
            [0] => Array
                    [0] => discount_sku_lookup*.csv
                    [1] => 1
            [1] => Array
                    [0] => period_defaults*.csv
                    [1] => 1
            [2] => Array
                    [0] => master_sku_list*.csv
                    [1] => 1
            [3] => Array
                    [0] => location_lookup*.csv
                    [1] => 1
            [4] => Array
                    [0] => locator_lookup*.csv
                    [1] => 1
            [5] => Array
                    [0] => indirect_dealer_cost*.csv
                    [1] => 1
            [6] => Array
                    [0] => sku_rollup*.csv
                    [1] => 1
    [job_monthly_holoads] => Array
            [0] => Array
                    [0] => msc225*.txt
                    [1] => 1
            [1] => Array
                    [0] => eom02a*.txt
                    [1] => 1
            [2] => Array
                    [0] => ema001*.txt
                    [1] => 1
            [3] => Array
                    [0] => ema003*.txt
                    [1] => 1
            [4] => Array
                    [0] => eom003*.txt
                    [1] => 1
            [5] => Array
                    [0] => eom002*.txt
                    [1] => 1
            [6] => Array
                    [0] => eom001*.txt
                    [1] => 1
            [7] => Array
                    [0] => eom004*.txt
                    [1] => 1
            [8] => Array
                    [0] => eom016*.txt
                    [1] => 1
            [9] => Array
                    [0] => eom10x*.txt
                    [1] => 1
            [10] => Array
                    [0] => eom010*.txt
                    [1] => 1
    [job_net_biapia_deferred_rev] => Array
            [0] => Array
                    [0] => net_biapia_def_revenue_adj*.csv
                    [1] => 1
Here is the second one again marked with &&&&&&&&&&&&& to show the inserted array.
Notice how the previous inserted array is gone from the array.
FOUND##### pia_rate_plans.*\.csv
Array
            [0] => Array
                    [1] => 1
                    [2] => Array
            [1] => Array
                    [1] => 1
                    [2] => Array
            [2] => Array
                    [1] => 1
                    [2] => Array
                            [0] => Array
                                    [0] => pia_rate_plans_20061031.csv      &&&&&&&&&&&&&&&
                                    [1] => 144                                           &&&&&&&&&&&&&&&
                                    [2] => 11/01/2006 16:27                       &&&&&&&&&&&&&&&
            [3] => Array
                    [1] => 1
            [4] => Array
                    [0] => eom033*.txt
                    [1] => 1
            [5] => Array
                    [1] => 1
            [6] => Array
                    [1] => 1
            [0] => Array
                    [1] => 1
            [1] => Array
                    [1] => 1
            [2] => Array
                    [1] => 1
            [3] => Array
                    [1] => 1
            [4] => Array
                    [1] => 1
            [5] => Array
                    [1] => 1
            [0] => Array
                    [1] => 31
            [0] => Array
                    [1] => 1
            [1] => Array
                    [1] => 1
            [2] => Array
                    [1] => 1
            [3] => Array
                    [1] => 1
            [0] => Array
                    [1] => 1
            [0] => Array
                    [0] => bil001*.csv
                    [1] => 28
            [1] => Array
                    [0] => cyc002*.csv
                    [1] => 28
            [2] => Array
                    [0] => ivprch*.csv
                    [1] => 31
            [3] => Array
                    [1] => 28
            [0] => Array
                    [1] => 1
            [1] => Array
                    [1] => 1
            [2] => Array
                    [1] => 1
            [3] => Array
                    [1] => 1
            [4] => Array
                    [1] => 1
            [0] => Array
                    [1] => 1
            [1] => Array
                    [1] => 1
            [2] => Array
                    [1] => 1
            [3] => Array
                    [1] => 1
            [4] => Array
                    [1] => 1
            [5] => Array
                    [1] => 1
            [6] => Array
                    [1] => 1
            [0] => Array
                    [0] => msc225*.txt
                    [1] => 1
            [1] => Array
                    [0] => eom02a*.txt
                    [1] => 1
            [2] => Array
                    [0] => ema001*.txt
                    [1] => 1
            [3] => Array
                    [0] => ema003*.txt
                    [1] => 1
            [4] => Array
                    [0] => eom003*.txt
                    [1] => 1
            [5] => Array
                    [0] => eom002*.txt
                    [1] => 1
            [6] => Array
                    [0] => eom001*.txt
                    [1] => 1
            [7] => Array
                    [0] => eom004*.txt
                    [1] => 1
            [8] => Array
                    [0] => eom016*.txt
                    [1] => 1
            [9] => Array
                    [0] => eom10x*.txt
                    [1] => 1
            [10] => Array
                    [0] => eom010*.txt
                    [1] => 1
            [0] => Array
                    [1] => 1
Thanks.
hapaboy2059
hapaboy2059
  • 3
  • 2
VoteyDiscipleCommented:
This part is what doesn't make sense to me:
                    $matchcount++;
You're reusing [2] every time, so you'll never get new items.
Let me suggest this instead:
                 $temp =  array();
                    $temp[] = $filelist[$file_key];
                    $matchcount++;
Then after the loop do:
$jobnames[$jobnamelist[$i][$j]][$key1][] = $temp
And by "after the loop" I mean after the inner foreach loop.
hapaboy2059Author Commented:
The hard coded two is becuase the 0 and 1 elements have already been defined as the filemask and the daily_fl so I insert the new array at index 2.
That clearly works fine the first time, but then the next element doesn't belong at [2] anymore, it belongs at [3].  If you put it back at [2] you're replacing what you already put there, and you get the results you're seeing now.  Since that's not what you want, use [] without any explicit index to mean "insert at the end of the array" (regardless of how many things are already in it).
That's precisely what the code I've provided does.  In particular the following line uses the [] syntax:
This is the code that works now:
Thanks!
     $check1 = 1;
        // loops over each
           $check2 = 1;
              $matchcount = 0;
              $countin =0;
                // $jobnames[$jobnamelist[$i][$j]][$key1][2] =  array();
                    $array = $filelist[$file_key];
                    $jobnames[$jobnamelist[$i][$j]][$key1][2][$countin][0] = $array[0];
                    $jobnames[$jobnamelist[$i][$j]][$key1][2][$countin][1] = $array[1];
                    $jobnames[$jobnamelist[$i][$j]][$key1][2][$countin][2] = $array[2];
                    $matchcount++;
                    $countin++;
                 $check2 = 0;
              if($matchcount == 0)
                 $jobnames[$jobnamelist[$i][$j]][$key1][2][$countin][0] = 'missing';
                 $jobnames[$jobnamelist[$i][$j]][$key1][2][$countin][1] = 'missing';
                 $jobnames[$jobnamelist[$i][$j]][$key1][2][$countin][2] = 'missing';
           if($check2 == 1)
           else
             $check1 = 0;
     if($check1 == 1)
Join & Write a Comment
Free Tool: SSL Checker
Scans your site and returns information about your SSL implementation and certificate. Helpful for debugging and validating your SSL configuration.
  • 3
  • 2
