Problem in MS SQL Connection Using JSP
Helo,
I tried to connect to MS SQL using JSP and JTDS driver. I got the following errors:
[ErrorMessage-START]
An error occurred at line: 4 in the jsp file: /search2.jsp
Generated servlet error:
ds cannot be resolved
con cannot be resolved
stm cannot be resolved
result cannot be resolved
e cannot be resolved
[ErrorMessage-END]
Below are all the related files:
1. search.jsp (in C:\apache-tomcat\webapps\leone\)
2. context.xml (in C:\apache-tomcat\conf\Catalina\localhost\)
search.jsp:
<%@ page import="java.text.*,javax.sql.*,javax.naming.*, com.syslore.multicolumn.*" %>
<html>
<body>
try {
Context context = new InitialContext();
Context envCtx = (Context) context.lookup("java:comp/env");
ds = (DataSource)envCtx.lookup("jdbc/SQLServer");
if (ds != null) {
  con = ds.getConnection();
  stm = con.createStatement();
  result = stm.executeQuery("SELECT * FROM Employees");
  }//if
catch (NamingException ex) {
  ex.printStackTrace();
} catch (SQLException e) {
  e.printStackTrace();
}//try
</body>
</html>
context.xml:
<Context path="/TesteSQLServer" docBase="TesteSQLServer" debug="5" reloadable="true">
  <Resource name="jdbc/SQLServer"
    auth="Container"
    type="javax.sql.DataSource"
    maxActive="10"
    maxIdle="1"
    maxWait="10000"
    username="26226255"
    password="tt"
    driverClassName="net.sourceforge.jtds.jdbc.Driver"
    url="jdbc:jtds:sqlserver://XX.XX.XX.XX/ControleOper_DES" />
</Context>
Anyone has idea of how to fix the error?
Thanks.
SWB-Consulting
SWB-Consulting
3 Solutions
jaggernatCommented:
Replace
with
Connection con = ds.getConnection();
Statement stm = con.createStatement();
ResultSet  result = stm.executeQuery("SELECT * FROM Employees");
SWB-ConsultingAuthor Commented:
After I added the above (as you recommended) below is the error message:
Connection cannot be resolved to a type
Statement cannot be resolved to a type
SQLException cannot be resolved to a type
But then I replace
with
DataSource ds = (DataSource)envCtx.lookup("jdbc/SQLServer");
Below are the error messages (notice the ds is fixed, but the rest remains the same):
Hmm.. what did I miss?
mbvvsatishCommented:
you have imported javax.sql.*;
you also need to import java.sql.*;
We value your feedback.
Thanks. It's much better now after adding the object declaration at the front and importing java.sql.*.  However, there is still one error:
"The type ResultSet is ambiguous"
Is it because wrong connection parameters (url) in context.xml or a pure java error?
orhanbabaCommented:
use full package name
java.sql.ResultSet result;
yes.  now it works!
