Help required to send open command to remote system using PSEXEC
Posted on 2006-11-22
Last Modified: 2011-09-20
 When I enter the following code into cmd or in a batch file and run locally, it works perfectly:
"C:\Program Files\Adobe\Adobe After Effects 7.0\Support Files\AfterFX.exe" "-wf  V:\01_AE_Watch_Folder\"
However trying to use the above line with PSEXEC to open the ap remotely like this:
psexec \\IP_Address -i -s "C:\Program Files\Adobe\Adobe After Effects 7.0\Support Files\AfterFX.exe" "-wf  V:\01_AE_Watch_Folder\"
Opens the AfterFX.exe fine but doesn't open it in Watch Folder mode which it does when I either run the batch file locally or by pasting the first line of code into cmd as mentioned above.
any ideas?
Question by:sany101
  • 3
LVL 43
Expert Comment
by:Steve Knight
I imagine the drive V: isn't  avaialble to it?  Havent got the syntax to hand to check but I imagine that will run it as a local system user and not the currently logged in user.  You could copy a batch file containing a net use command for v: then run your commandline or run it against a local c: path I guess.  There is an option to copy and run a batch using psexec afai rememeber.
Can't check correct syntax at the moment because I'm on a pda but I seem to remember an option to run psexec as the logged on user?
LVL 43
Accepted Solution
Steve Knight earned 2000 total points
Right checked ...
-c option will copy the file first.  You can't specify logged on user, only a speciifc user using -user so I think you need to map the drive first:
So batch file on your system or network drive somewhere then run it with the -c option:
psexec \\IP_Address -I -c c:\scripts\yourbatch.cmd
@echo off
rem Run the prog remotely
net use v: \\server\share /user:username password
rem Should delete the batch file once run
del %0
Author Comment
Awsome!! Thanks you so much
LVL 43
Expert Comment
by:Steve Knight
No problem,
Free Tool: SSL Checker
Scans your site and returns information about your SSL implementation and certificate. Helpful for debugging and validating your SSL configuration.
Join & Write a Comment
Recently, I had the need to build a standalone system to run a point-of-sale system. I’m running this on a low-voltage Atom processor, so I wanted a light-weight operating system, but still needed Windows. I chose to use Microsoft Windows Server 200…
Setting up a Microsoft WSUS update system is free relatively speaking if you have hard disk space and processor capacity.   However, WSUS can be a blessing and a curse. For example, there is nothing worse than approving updates and they just have…
Watch the video to know how one can repair corrupt Exchange OST file effortlessly and convert OST emails to MS Outlook PST file format by using Kernel for OST to PST converter tool. It can convert OST to MSG, MBOX, EML to access them. It can migrate…
From store locators to asset tracking and route optimization, learn how leading companies are using Google Maps APIs throughout the customer journey to increase checkout conversions, boost user engagement, and optimize order fulfillment. Powered …
621 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
