hcrepairs
any help for power issue with esystem 3083
HI all
i have a e-system 3083 laptop that has suddenly died. it is shorting.
the power adaptor is ok and i have checked it with another P.A.
when you plug the P.A into the laptop, the power light of the laptop starts blinking as though it is shorting. and when you plug another P.A into the laptop, you can hear the noise as though this too is shorting.
any suggestions?
by the way, i haven't got a clue about how this points systems works. aslo looking for an easy life
any suggestions?
