it2gostl
SCO OpenServer 5 scsi disk, need to mount it in a different machine for data recovery. HELP!
Hello!
I have a scsi hard drive with SCO OpenServer 5 on it (unknown revision, just says 5 on the boot screen). The disk is OK but the original hardware took a power hit. I need to access some files on the disk and copy them to a PC readable medium (FAT/NTFS/ETC).
What I have:
The SCSI disk which fails to mount the rootfs on bootup and halts
A SCO install CD-ROM with which I made install disks, but I do NOT have a SCSI CD-ROM so I can't do install!! (wasted all day trying to get a wd driver to work).
I need to get to mount /dev/u at point /usr2
PLEASE HELP. Lots of points will be rewarded, I will be posting many other questions on this topic today I am sure. Thanks.
What I have:
I managed to get this working but since you took the time to reply I will give you the points! Thanks!
But now there is no fsck command available and when I try to mount /dev/root /mnt I get an error saying mount: Bad address
Thank you very much for any assistance.
