troubleshooting Question
Problem with using system.collections.arraylist()
Avatar of mightofnight
mightofnightFlag for United States of America asked on
Visual Basic.NET
9 Comments2 Solutions370 ViewsLast Modified:
I am trying my first VB project using multidimensional arrays (and i admit i am struggling)
I have figured out about 4 different methods and decided to use the system.collections.arraylist() cause it's simple and thats fits plan of my project.
I am down to this one problem..
(Here is a sniplit of code where i am confused)
            strRegistryArray.Add(aRowArray)
            aRowArray.Clear()
The problem is that i add an array element using the variable aRowArray and then try to clear it after it is added so that i can rebuild it again. (it's part of a loop)
anyway when i do the clear it also clears out the original value from the strRegistryArray.  I now this is a byRef and byValue thing but i just don't know how to get around it.
Thanks for any help!
Arthur_Wood
Unlock 2 Answers and 9 Comments.
Learn from the best
Try for 7 days
-Mike Kapnisakis, Warner Bros
