500 POINTS, URGENT, PLZ HELP!!... PROBLEM WITH VARIABLES, TRY CATCH BLOCKS...
try
check = false;
catch (the exception)
try
      if (check ==true)
>> I get an error saying that check variable is not found. I am certain its because its in different try catch blocks. Is there anyway that i can pass the variable to the next try catch block.
>>Or if there is any other way around this. The Try Catch blocks are both different, one being
-->>MessagingException
-->>SQLException
deepanp
deepanp
  • 8
  • 6
  • 6
2 Solutions
CEHJCommented:
Define 'check' before first block
deepanpAuthor Commented:
-->Define 'check' before first block
you mean Boolean check = false;
CEHJCommented:
boolean check = false;
The new generation of project management tools
With monday.com’s project management tool, you can see what everyone on your team is working in a single glance. Its intuitive dashboards are customizable, so you can create systems that work for you.
objectsCommented:
try the following:
boolean check = false;   // declare variable *outside* try/catch blocks
try
   check = false;
try
      if (check ==true)
hey objects,
i'm sorry, i should have also mentioned that the boolean check = false; --> is in the catch block of the first try catch blocks.
objectsCommented:
yes, I'm saying you need to move it *outside* so its visibale in both blocks
See the code I posted above
objectsCommented:
variables declared inside a try/catch block are only visible (scope) withing that try/catch block
-->>yes, I'm saying you need to move it *outside* so its visibale in both blocks
-->>i understand that, however, if a catch is caught, i need the boolean to be false, otherwise true. so to my knowledge, i believe this will not work if i have it outside of the catch, as the var will always be false.
-->>variables declared inside a try/catch block are only visible (scope) withing that try/catch block
->Is there any way where i can catch both of teh exceptions then, essentially joining the try, catch blocks. Or any way to define the variable to be called from outside, idea if possible like making it Perminent throughout...
objectsCommented:
boolean check = true;   // declare variable *outside* try/catch blocks
try
   check = false;
try
      if (check ==true)
-->>HAHA,
-->>:P.....
-->>I started to think.. and logically thought of a for loop outside of all of this try catch blocks, then implemented the
-->>break statement when a catch was caused... making the loop break... the loop is only in one iteration...
:P
-->>Practical Method, i'd say hey?
-->>Thanks Guys...
-->>I'll get the points refunded.
objectsCommented:
what i suggested above will work and avoids need for using break :)
-->>The break, i'd say is a much easier method, Don't ask why.
-->>However you have figured the solution.
-->>Therefore points awarded to you.
-->>Thanks Objects and CEHJ...For all the Help...:-D...
CEHJCommented:
Move the statement to where i mentioned. You can do what you like with it then
CEHJCommented:
deepanp - can you explain why you accepted a comment that repeats the answer i'd already given?
-->>CEHJ - I'm sorry, as reading above, I noticed I missed a message from you.
-->>If its possible, I will contact admin, and askthem to split points instead..
-->>However, If this is possible.
-->>If not then I do apologise.
-->>I might well be posting another problem soon - :)
CEHJCommented:
It is possible. I'll alert them for you
-->>Please send me the link, if you are posting the message...
-->>Or do you want me to. If so, where isit again to post the issues...?
objectsCommented:
What CEHJ suggested would not work. You were setting the flag in the wrong place.
What I suggested was not the same as what CEHJ stated, a split is not necessary.
Try his suggestion if you like, check will never get set :)
CEHJCommented:
Let me know if you can see the difference between the accepted and assisted - i can't ;-)
  • 8
  • 6
  • 6
