Help with RijndaelManaged encryption problem using c#
I need some help figuring out an issue using RijndaelManaged to encrypt and decrypt a string.
I took the code from
http://www.obviex.com/samples/Encryption.aspx
and used as is get an error about padding invalid SO I changed the padding to Padding.None and it seems to encrypt..or at least it returns an encrypted value without givig me the padding error.
but when I decrypt the string it doesnt return as the original value but instead returns as some gobbledeegoock
Below is my code and this is the data I feed to the methods....but before you loko at the code this is what I encrypt
7henewp@s5phr@se
this is what returns encrypted.
gPtlrVtf+cKn0Yu7EQrgDQ==
but this is what gets decrypted.
h`*B7*Z
protected void Button1_Click(object sender, EventArgs e)
        string plainText = "7henewp@s5phr@se";
        string passPhrase = "encrypt7heb@st@rd";
        string saltValue = "2s@lty4me";
        string hashAlgorith = "SHA1";
        int pwIterations = 7;
        string initVector = "@1B9f5P2!0n3G69T";
        int keySize = 256;
        TextBox1.Text = plainText;
        string cipherText = RijndaelSimple.Encrypt(plainText,
                                                   passPhrase,
                                                   saltValue,
                                                   hashAlgorith,
                                                   pwIterations,
                                                   initVector,
                                                   keySize);
        Label1.Text = cipherText;
        string results = RijndaelSimple.Decrypt(cipherText,
                                                passPhrase,
                                                saltValue,
                                                hashAlgorith,
                                                pwIterations,
                                                initVector,
                                                keySize);
        Label2.Text = results;
public class RijndaelSimple
      public static string Encrypt(string plaintext,
                                 string passPhrase,
                                 string saltValue,
                                 string hashAlgorithm,
                                 int pwIterations,
                                 string initVector,
                                 int keySize)
        byte[] initVectorBytes = Encoding.ASCII.GetBytes(initVector);
        byte[] saltValueBytes = Encoding.ASCII.GetBytes(saltValue);
        byte[] plainTextBytes = Encoding.UTF8.GetBytes(plaintext);
        PasswordDeriveBytes password = new PasswordDeriveBytes(passPhrase, saltValueBytes, hashAlgorithm, pwIterations);
        byte[] keyBytes = password.GetBytes(keySize / 8);
        RijndaelManaged symmetricKey = new RijndaelManaged();
        symmetricKey.Mode = CipherMode.CBC;
        symmetricKey.Padding = PaddingMode.None;
        ICryptoTransform encryptor = symmetricKey.CreateDecryptor(keyBytes, initVectorBytes);
        MemoryStream memoryStream = new MemoryStream();
        CryptoStream cryptoStream = new CryptoStream(memoryStream, encryptor, CryptoStreamMode.Write);
        cryptoStream.Write(plainTextBytes, 0, plainTextBytes.Length);
        cryptoStream.FlushFinalBlock();
        byte[] cipherTextBytes = memoryStream.ToArray();
        memoryStream.Close();
        cryptoStream.Close();
        string cipherText = Convert.ToBase64String(cipherTextBytes);
        return cipherText;
    public static string Decrypt(string ciphertext,
                                 string passPhrase,
                                 string saltValue,
                                 int pwIterations,
                                 string initVector,
                                 int keySize)
        byte[] cipherTextBytes = Convert.FromBase64String(ciphertext);
        ICryptoTransform decryptor = symmetricKey.CreateDecryptor(keyBytes, initVectorBytes);
        MemoryStream memoryStream = new MemoryStream(cipherTextBytes);
        CryptoStream cryptoStream = new CryptoStream(memoryStream, decryptor, CryptoStreamMode.Read);
        byte[] plainTextBytes = new byte[cipherTextBytes.Length];
        int decryptedByteCount = cryptoStream.Read(plainTextBytes, 0, plainTextBytes.Length);
        string plainText = Encoding.UTF8.GetString(plainTextBytes, 0, decryptedByteCount);
        return plainText;
Prysson
Prysson
kingtam2000Commented:
It's caused by the fact that you are decrypting the string twice, as the encryption function is the same as the decryption function.  You should change the following code in the encrypt function to encrypt it:
to
       ICryptoTransform encryptor = symmetricKey.CreateEncryptor(keyBytes, initVectorBytes);
Once that is changed it should work.
Hope that helps.
PryssonAuthor Commented:
Awesome catch..I dpont know how many times I looked through that and kept missing it.
Thanks for the help!!!
