Solved
PLEASE HELP. 500 EASY POINTS FOR URGENT HELP!! SIMPLE PROBLEM, DOESN'T SEEM TO WORK!!
Posted on 2007-03-27
12
Last Modified: 2010-07-27
Hey Experts, I'm really fustrated, for some reason this loop doesn't seem to work when going through..
I'm using postgres which gets a sequence count from a table in a col.. the rs.next scans through the rows, i.e. 1,2,3,4,5,6,7,8.... 8 being the highest say for example, i want the if condition to be true. However, this does not seem to work.
Please reply if you hace any questions.
Thanks Experts.
int a = 0;
while (rs.next())
                 String temp2 = rs.getString ("count");
                 System.out.println("temp2="+ temp2);
                 int i = Integer.parseInt(temp2);
                 if (a>i)
                          a++;
                          String astring = Integer.toString (a);
                    Statement temp3 = temp.createStatement();
                    System.out.println("Whats Up-"+astring);
                  temp3.addBatch("INSERT INTO count_table (name) VALUES ('User generate value = " + astring + "');");
                  temp3.executeBatch();
                  collem = "al" + astring;
                  break;
Question by:deepanp
  • 5
  • 4
  • 3
12 Comments
LVL 92
Expert Comment
by:objects
>                 if (a>i)
shouldn't that be
                 if (a<i)
what is it u want to achieve?
LVL 30
Expert Comment
by:Mayank S
Should be done outside the while () I guess.
>> break;
Not required perhaps otherwise you will end up looping out when you shouldn't.
Do you need to end the query with a semi colon?
LVL 92
Accepted Solution
by:
objects earned 2000 total points
why don't u just select the max directly
select max(count) from ...
We value your feedback.
LVL 30
Expert Comment
by:Mayank S
Perhaps the create statement too.... what's the use of executing batch if you want to execute only one?
Author Comment
by:deepanp
say the col sequence number was 30 right...
the while (rs.next()) will obv go through the rows.. i.e lookin at the count col.. i.e. 1,2,3,4,5,6,.. when it goes through the if loop should check and basically go through the if loop when it reaches the highest value in the col..i.e. if it were 6.. den da next iteration would be 7.. 7 being higher than that of 6.. therefore inserting into table... therefore the next table sequence is then 8.. u get wt i mean?
Author Comment
by:deepanp
Hey Objects
I'm going to check out the Maxcount table out right now.. n see if i can try this way... Thanks..
-->>i will post shortly.. so please monitor email... Thanks guys..
Author Comment
by:deepanp
if you could give a link for the maxcount. i cannot seem to fine any links atm..
Cheers!
Author Comment
by:deepanp
Good technique, and it seems to work fine..!
Thanks to objects mayankeagle for replying.
LVL 30
Expert Comment
by:Mayank S
But somehow you didn't like my reply :)
Author Comment
by:deepanp
lol... i did...and i understood what you said.. but i had two statements.. one was outside... inside that while loop... was another statement.. thats why i avoided that comment.... :-)
LVL 30
Expert Comment
by:Mayank S
I see addBatch () and executeBatch () both inside the while loop
Get your problem seen by more experts
Be seen. Boost your question’s priority for more expert views and faster solutions
Introduction This article is the second of three articles that explain why and how the Experts Exchange QA Team does test automation for our web site. This article covers the basic installation and configuration of the test automation tools used by…
Basic understanding on "OO- Object Orientation" is needed for designing a logical solution to solve a problem. Basic OOAD is a prerequisite for a coder to ensure that they follow the basic design of OO. This would help developers to understand the b…
Viewers learn how to read error messages and identify possible mistakes that could cause hours of frustration. Coding is as much about debugging your code as it is about writing it. Define Error Message: Line Numbers: Type of Error: Break Down…
This tutorial will introduce the viewer to VisualVM for the Java platform application. This video explains an example program and covers the Overview, Monitor, and Heap Dump tabs.
Suggested Courses
Course of the Month10 days, 18 hours left to enroll
571 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
