Randall-B
ASP Classic: Problem with DSN-less Connection to MySQL
I'm trying to connect ASP classic to MySQL, running on localhost. Here's my setup:
- ASP is on XP Pro IIS 5.1 at port 1080 (localhost:1080)
- The MySQL server is part of WAMP at port 80.
- Installed the MySQL ODBC 3.51 Driver
- Although I'm trying to use a DNS-less connection, I have set up a System DSN named "MySQL" using the MySQL ODBC 3.51 Driver. The parameters are: localhost, root, (no password), and the database name "mydata".
- Tested the User DSN, and it connects OK.
- Restarted computer, rechecked DSN; connects fine to the database "mydata" to be sure everything works.
The ASP page runs fine as a "hello world" script (localhost:1080/helloworld .asp).
However, it gives an error message when I add the database connection string for a DSN-less connection.
Update: I just got it to work with this:
Dim oConn, rs, sql
Set oConn = Server.CreateObject("ADODB .Connectio n")
oConn.Open "DRIVER={MySQL ODBC 3.51 Driver};" & _
"SERVER=localhost;" & _
"DATABASE=mydata;" & _
"USER=root;" & _
"PASSWORD=;"
[etc.]
and also with:
Dim oConn, rs, sql
Set cn = Server.CreateObject("ADODB .Connectio n")
cn.Open "DRIVER={MySQL ODBC 3.51 Driver};" & _
"USER=root;" & _
"PASSWORD=;"
and also with:
Dim cn, rs, sql
"Server=localhost;" & _
"Port=3306;" & _
"Option=16384;" & _
"Stmt=;" & _
"Database=mydata;" & _
"Uid=root;" & _
"Pwd=;"
I also tried a remote connection, to a MySQL server out on the Internet, and it worked like this when calling the script from localhost:1080 :
oConn.Open "Driver={MySQL ODBC 3.51 Driver};" & _
"Server=db1.mydatabaseserv er.com;" & _
"Port=3306;" & _
"Option=131072;" & _
"Stmt=;" & _
"Uid=myUsername;" & _
"Pwd=myPassword"
But it won't work on my ISP server
What if the ASP script is hosted on a Windows ISP server where I do not have access to installing the MySQL ODBC Driver nor a DSN? Is there any other way to connect?
The error I'm getting, when trying to use the script on an ISP server, is:
Microsoft-IIS/5.0
Microsoft OLE DB Provider for ODBC Drivers error '80004005'
[Microsoft][ODBC Driver Manager] Data source name not found and no default driver specified
Dim oConn, rs, sql
"USER=root;" & _
"PASSWORD=;"
[etc.]
and also with:
Dim oConn, rs, sql
"USER=root;" & _
"PASSWORD=;"
and also with:
Dim cn, rs, sql
"Port=3306;" & _
"Option=16384;" & _
"Stmt=;" & _
"Uid=root;" & _
"Pwd=;"
"Port=3306;" & _
"Stmt=;" & _
"Pwd=myPassword"
Microsoft-IIS/5.0
Or could SQLite work somehow?
I have decided to use MS SQL Server, which is available on that server and apparently has the right ODBC connections installed. So I used the trial version of DBManager Professional to import my MySQL tables into MS SQL, and it seems to be working OK. Thanks.
Microsoft-IIS/5.0
error '80004005'
Does it look like they don't have the MySQL ODBC driver installed? If that's the case, I guess I'm stuck unless I can get them to install the driver on their server?
What if I use MS SQL instead? Do you know if that would also require an ODBC driver to be installed?
