groknit
Cisco Routing Issue over Point-To-Point T1 - TUNNEL Works fine over Internet Circuits!! HELP!
I have 2 sites. Site A and Site B. Each site has an internet T1 and an ipsec tunnel configured. This configuration works perfectly. Now I am trying to keep the internet T1 and use it for internet traffic and install a P2P T1 and use it for corporate traffic. I can get the circuit up and running and ping back and forth without a problem. As soon as I add a static route on each router to prefer to go over the new P2P T1, I can ICMP from one internet network to the other no problem. However, on Site A I can RDP to Site B. But Site B can not RDP to site A. Now mind you that the only thing I did was change the routing!! The tunnels work fine if I remove the static route or shutdown the P2P T1 interfaces. This is a really strange problem! I think there must be a simple solution. Here are the configs:
Site A Router:
version 12.1
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname SITE A
logging rate-limit console 10 except errors
enable secret 5 X
username admin privilege 15 password 7 XXXXX
clock timezone PST -8
clock summer-time PDT recurring
ip subnet-zero
no ip finger
no ip telnet comport enable
no ip domain-lookup
ip audit notify log
ip audit po max-events 100
call rsvp-sync
controller T1 1/0
channel-group 0 timeslots 1-24
description T1 to PACIS410
controller T1 1/1
description T1 to QOV400 (PROBLEM CIRCUIT)
controller T1 1/2
controller T1 1/3
interface FastEthernet0/0
description to local LAN
ip address 66.x.x.1 255.255.255.224
duplex full
speed 100
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial1/0:0
description PASGV to PACIS410 (NOT HAVING A PROBLEM WITH THIS CIRCUIT)
bandwidth 1500
ip address 10.2.1.1 255.255.255.252
encapsulation ppp
interface Serial1/1:0
description PASGV to QOV400 - (PROBLEM CIRCUIT)
bandwidth 1500
ip address 67.x.x.54 255.255.255.252
encapsulation ppp
shutdown
interface ATM2/0
no ip address
shutdown
no ima-group
no atm ilmi-keepalive
interface ATM2/1
no ip address
ima-group 1
interface ATM2/ima1
description ATM-IMA TO PBI 4.5Mb
ip address 64.x.x.x 255.255.255.252 (INTERNET)
ip access-group 102 in
pvc 2/35
encapsulation aal5snap
interface ATM2/2
no ip address
ima-group 1
interface ATM2/3
no ip address
ima-group 1
interface ATM2/4
no ip address
shutdown
no ima-group
interface ATM2/5
no ip address
shutdown
no ima-group
interface ATM2/6
no ip address
shutdown
no ima-group
interface ATM2/7
no ip address
shutdown
no ima-group
ip classless
ip route 0.0.0.0 0.0.0.0 64.174.126.201
ip route 67.x.x.48 255.255.255.252 67.x.x.53
ip route 216.x.x.6 255.255.255.255 10.2.1.2 (NOT HAVING A PROBLEM)
no ip http server
access-list 1 permit 66.x.x.3
access-list 102 deny tcp any any range 135 139
access-list 102 deny tcp any any eq 3389
access-list 102 deny udp any any range 135 netbios-ss
access-list 102 deny tcp any any eq 445
access-list 102 deny udp any any eq 1434
access-list 102 deny tcp any any eq telnet
access-list 102 deny ip 207.150.160.0 0.0.3.255 any
access-list 102 permit ip any any
snmp-server community X
gatekeeper
shutdown
line con 0
transport input none
line aux 0
line vty 0 4
access-class 1 in
password 7 XXXXX
login local
transport input telnet
line vty 5 15
no login
end
SITE B
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service sequence-numbers
hostname SITE B
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 8
logging buffered 51200 warnings
enable secret X
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
no ip source-route
ip cef
ip inspect name SDM_LOW cuseeme
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp
ip inspect name SDM_LOW udp
ip inspect name SDM_LOW vdolive
ip tcp synwait-time 10
no ip bootp server
no ip domain lookup
crypto pki trustpoint TP-self-signed-3809913011
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certifi cate-38099 13011
revocation-check none
rsakeypair TP-self-signed-3809913011
crypto pki certificate chain TP-self-signed-3809913011
XXXX
quit
username admin privilege 15 secret 5 XXXXXX
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key X address 216.x.x.132
crypto isakmp key x address 66.x.x.18
crypto ipsec transform-set vpn esp-3des esp-sha-hmac
crypto map qov 1 ipsec-isakmp
set peer 216.x.x.132 (NOT HAVING A PROBLEM)
set transform-set vpn
match address 120
crypto map qov 2 ipsec-isakmp
set peer 66.x.x.18 (TUNNEL OK WHEN GOING THROUGH INTERNET)
match address 110
interface Null0
no ip unreachables
description Outside Interface from Nortel BCM50e s768k$ETH-WAN$$FW_OUTSIDE$
ip address 67.x.x.50 255.255.255.252 (INTERNET, just trust me)
ip access-group 101 in
ip verify unicast reverse-path
no ip redirects
no ip unreachables
no ip proxy-arp
ip inspect SDM_LOW out
ip nat outside
ip virtual-reassembly
ip route-cache flow
speed 10
full-duplex
no mop enabled
crypto map qov
description Internal Interface to 3COM Switch$ETH-LAN$$FW_INSIDE$
ip address 10.1.116.1 255.255.255.0
ip access-group 100 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
speed 100
full-duplex
no mop enabled
interface Serial0/0/0
bandwidth 1500
ip address 67.x.x.53 255.255.255.252 (PROBLEM CIRCUIT)
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation ppp
ip route-cache flow
ip classless
ip route 0.0.0.0 0.0.0.0 67.x.x.49 name NortelDefaultGateway
ip route 66.x.x.0 255.255.255.224 67.x.x.54
ip http server
ip http access-class 2
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat pool Internet 67.x.x.50 67.x.x.50 netmask 255.255.255.240
ip nat inside source route-map nonat pool Internet overload
logging trap warnings
access-list 1 permit 10.1.116.0 0.0.0.255
access-list 2 permit 66.x.x.3
access-list 2 permit 10.1.116.0 0.0.0.255
access-list 2 permit 172.29.20.0 0.0.3.255
access-list 100 remark auto generated by SDM firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 deny ip 67.x.x.48 0.0.0.15 any
access-list 100 deny ip host 255.255.255.255 any
access-list 100 deny ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by SDM firewall configuration
access-list 101 remark SDM_ACL Category=1
access-list 101 remark Auto generated by SDM for NTP (123) 192.12.19.20
access-list 101 permit udp host 192.12.19.20 eq ntp host 67.x.x.50 eq ntp
access-list 101 permit ahp host 66.x.x.18 host 67.x.x.50
access-list 101 permit esp host 66.x.x.18 host 67.x.x.50
access-list 101 permit udp host 66.x.x.18 host 67.x.x.50 eq isakmp
access-list 101 permit udp host 66.x.x.18 host 67.x.x.50 eq non500-isakmp
access-list 101 permit ip 172.29.20.0 0.0.3.255 10.1.116.0 0.0.0.255
access-list 101 permit ahp host 216.x.x.132 host 67.x.x.50
access-list 101 permit esp host 216.x.x.132 host 67.x.x.50
access-list 101 permit udp host 216.x.x.132 host 67.x.x.50 eq isakmp
access-list 101 permit udp host 216.x.x.132 host 67.x.x.50 eq non500-isakmp
access-list 101 permit ip 10.1.100.0 0.0.0.255 10.1.116.0 0.0.0.255
access-list 101 deny ip 10.1.116.0 0.0.0.255 any
access-list 101 permit icmp any host 67.x.x.50 echo-reply
access-list 101 permit icmp any host 67.x.x.50 time-exceeded
access-list 101 permit icmp any host 67.x.x.50 unreachable
access-list 101 deny ip 10.0.0.0 0.255.255.255 any
access-list 101 deny ip 172.16.0.0 0.15.255.255 any
access-list 101 deny ip 192.168.0.0 0.0.255.255 any
access-list 101 deny ip 127.0.0.0 0.255.255.255 any
access-list 101 deny ip host 255.255.255.255 any
access-list 101 deny ip host 0.0.0.0 any
access-list 101 deny ip any any log
access-list 110 permit ip 10.1.116.0 0.0.0.255 172.29.20.0 0.0.3.255
access-list 120 permit ip 10.1.116.0 0.0.0.255 10.1.100.0 0.0.0.255
access-list 130 deny ip 10.1.116.0 0.0.0.255 10.1.100.0 0.0.0.255
access-list 130 deny ip 10.1.116.0 0.0.0.255 172.29.20.0 0.0.3.255
access-list 130 permit ip 10.1.116.0 0.0.0.255 any
no cdp run
route-map nonat permit 10
match ip address 130
control-plane
banner login ^CAuthorized access only. This system is the property of X. Disconnect IMMEDIATELY as you are not an authorized user! XXXXXX.^C
line con 0
logging synchronous
login local
transport output telnet
line aux 0
login local
line vty 0 4
access-class 2 in
privilege level 15
logging synchronous
login local
transport input telnet ssh
scheduler allocate 4000 1000
sntp server 192.12.19.20
end
SITE A has a PIX 525 and like I said the tunnels work fine over the internet so let me know if you need me to post that config!!!!
Help.. this one really has me stumped!!!
Site A Router:
version 12.1
hostname SITE A
enable secret 5 X
ip subnet-zero
no ip finger
no ip domain-lookup
ip audit notify log
call rsvp-sync
controller T1 1/0
controller T1 1/1
controller T1 1/2
controller T1 1/3
duplex full
speed 100
no ip address
shutdown
duplex auto
speed auto
bandwidth 1500
encapsulation ppp
bandwidth 1500
encapsulation ppp
shutdown
interface ATM2/0
no ip address
shutdown
no ima-group
interface ATM2/1
no ip address
ima-group 1
interface ATM2/ima1
pvc 2/35
interface ATM2/2
no ip address
ima-group 1
interface ATM2/3
no ip address
ima-group 1
interface ATM2/4
no ip address
shutdown
no ima-group
interface ATM2/5
no ip address
shutdown
no ima-group
interface ATM2/6
no ip address
shutdown
no ima-group
interface ATM2/7
no ip address
shutdown
no ima-group
ip classless
no ip http server
gatekeeper
shutdown
line con 0
line aux 0
line vty 0 4
access-class 1 in
password 7 XXXXX
login local
line vty 5 15
no login
end
SITE B
version 12.4
no service pad
hostname SITE B
boot-start-marker
boot-end-marker
enable secret X
no aaa new-model
resource policy
no mmi pvc
ip subnet-zero
no ip source-route
ip cef
no ip bootp server
no ip domain lookup
XXXX
quit
encr 3des
group 2
match address 120
match address 110
interface Null0
no ip unreachables
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip route-cache flow
speed 10
full-duplex
no mop enabled
crypto map qov
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
speed 100
full-duplex
no mop enabled
bandwidth 1500
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation ppp
ip route-cache flow
ip classless
ip http server
no cdp run
control-plane
line con 0
logging synchronous
login local
line aux 0
login local
line vty 0 4
access-class 2 in
privilege level 15
logging synchronous
login local
end
This is still an existing issue. The crypto map should still be the same right? The only change is to the router... I need the preferred traffic to go over the new line. It does in 1 direction but not the other.
No... can I NAT on both interfaces?? I guess maybe I would have to?
You want to ipsec tunnel across the new line? When you test, did you create a new crypto map (named differently from qov) and tie it to s0/0 on site b?
