Group By Clause Problem with MAX
Hi there I am problems with the select statement. I have to put MAX in front of all the select fields because if I dont I get.
Msg 8120, Level 16, State 1, Procedure P_SectorSkills_VerifierActivityDetailedTEST, Line 13
Column 'tblUsers.FirstName' is invalid in the select list because it is not contained in either an aggregate function or the GROUP BY clause.
Is there any way of modifying the query so that I dont have to use MAX because otherwise it just chooses the best one for each field :(
Here is the query,
SELECT
Max(o.Description) As OrgnisationName,
Max(u.Firstname) As FirstName,
Max(u.LastName)As Lastname,
Max(u.SignUpdate) As SignUpDate,
max(dbo.getmonthdate(t.TransDate)),
max(dbo.getmonth(t.TransDate)),
Sum(CASE t.TransType WHEN 1 THEN 1 ELSE 0 END) AS PassportsIssued,
Sum(CASE t.TransType WHEN 7 THEN 1 ELSE 0 END) AS PassportVerifications,
Sum(CASE t.TransType WHEN 8 THEN 1 ELSE 0 END) AS SkillVerifications
FROM
tblUsers u
INNER JOIN
tblOrganisations o
ON o.OrganisationID = u.VerifierOrganisationID
INNER JOIN tblTransactions t
ON t.PHID = u.PHID
WHERE
dbo.getmonth(t.Transdate) between dbo.getmonth(@startdate) and dbo.getmonth(@enddate)
AND (o.OrganisationID = (CASE WHEN @OrganisationID = 0 THEN o.OrganisationID ELSE @OrganisationID END))
AND (t.PHID = (CASE WHEN @VerifierID = 0 THEN t.PHID ELSE @VerifierID END))
AND u.SchemeID = @SchemeID
GROUP BY
o.Description, dbo.getmonthdate(t.TransDate), dbo.getmonth(t.TransDate)
ORDER BY
o.Description, dbo.getmonth(T.TransDate)
LVL 1
MayoorPatelAsked:
QlemoBatchelor, Developer and EE Topic AdvisorCommented:
Simple approach: put everything you want to have as a single row into group by. As is, for descrption, transdate you won't need a max or alike. Do you really want to group by description???
MayoorPatelAuthor Commented:
I only need the fields that ar ein the GROUP BY as the single row elements. ALL the other stuff ineed not be there, however if I remove the MAX part i get errors, can you help me figure out why?
If you don't need those values, why select them?`As far as I understand, your select should be
SELECT
o.Description As OrgnisationName,
dbo.getmonth(t.TransDate),
FROM
tblUsers u
INNER JOIN
tblOrganisations o
ON t.PHID = u.PHID
WHERE
GROUP BY
ORDER BY
Newly released Acronis True Image 2019
In announcing the release of the 15th Anniversary Edition of Acronis True Image 2019, the company revealed that its artificial intelligence-based anti-ransomware technology – stopped more than 200,000 ransomware attacks on 150,000 customers last year.
I do need the other elements in there. I only want the items in the groupby clause to be grouped by. The other elements in the select clause need only be selected as normal. However if I try doing
u.Firstname As FirstName,
u.LastName As Lastname,
u.SignUpdate  As SignUpDate,
I get this error
because firstname is not in an aggregate function OR in the groupby clause.
There is no sense in selecting columns you don't want to group. Certainly, you have more than one row for each (Descriptiom, monthname, month) group with different firstname, lastname, signupdate. Which one should be chosen for your sum rows?
Why not?
I only want to group on the columsn i have specified! Why cant i just have the others select as normal?
Let's assume the table example with columns a and b, and values
a  b
1  a
2  b
3  a
4  b
if you group only for column b, which value of a is the one to display? I.e. what should this result in:
select a, count(b) from table group by b
MohanKNairCommented:
Use Oracle analytical function for row number and select the first in sorted order
select emp_name, dept_id from (
select emp_name, dept_id, row_number() over(partition by dept_id order by empid) r1 from emp
WHERE r1=1
@MohanKNair: We are with MSSQL, aren't we?
Christopher KileCommented:
Why are you grouping by Organization and two dates across an entire set of users, then associating those values grouped across the users as values associated with each of those users?  This does not make sense.  If you want organizational totals, get them; if you want user totals, get them; don't make the organizational totals look like user totals.
Your GROUP BY must include every field that is not in an aggregate function.  Why don't you try this, possibly use it as a subquery, and see if it provides the information you actually need.
SELECT
S.OrgnisationName,
S.MonthDateTransDate,
S.MonthTransDate,
S.PassportsIssued,
S.PassportVerifications,
S.SkillVerifications
FROM
tblUsers AS u
INNER JOIN
SELECT
u.id AS UserID, -- you do have a unique record identifier for this table, yes?
dbo.getmonthdate(t.TransDate) AS MonthDateTransDate,
dbo.getmonth(t.TransDate) AS MonthTransDate,
FROM
tblUsers u
INNER JOIN
tblOrganisations o
ON t.PHID = u.PHID
WHERE
GROUP BY
o.Description, dbo.getmonthdate(t.TransDate), dbo.getmonth(t.TransDate), u.Firstname As FirstName, u.LastName As Lastname, u.SignUpdate As SignUpDate
) AS S
ON
u.id = S.id
Microsoft SQL Server 2005
