UNIX shell script to call and execute a SQL script in Oracle.
I have couple of SQL statements that does an INSERT, UPDATE, DELETE operations.
Now, I would like to create a shell script to automate the process in UNIX.
Can you please help me in constructing an UNIX shell script that automates the process by calling the file from a specified location on the UNIX and executing the SQL commands from the file in Oracle?
Currently, I am running the DML statements manually in TOAD.
I worked on UNIX environment before and did not recently.
The SQL statements can be in files (.txt, .sql)
Please help.
Thanks in advance.
RND2006Asked:
Steve WalesConnect With a Mentor Senior Database AdministratorCommented:
Try something like this:
Calling script (assuming oraenv is in your path):
#!/usr/bin/ksh
export ORACLE_HOME=/u01/oracle/product/9.2
export ORACLE_SID=mydb
export ORAENV_ASK=NO
. oraenv
sqlplus -s @myscript.sql
Then myscript.sql:
userid/password
insert.....
delete.....
update.....
exit
Make sure that the permissions on the .sql file are read only to the user running the script so that not everyone can see your user and password.
awking00Connect With a Mentor Commented:
my_shell_script:
sqlplus << EOF
userid/password@database
@unix_path/insert_script.sql
@unix_path/update_script.sql
@unix_path/delete_script.sql
exit
EOF
Then execute using -
./my_shell_script
Note - you may have to use the chmod command to make the my_shell_script executable.
imarediaConnect With a Mentor Commented:
Create a script file "call_ora_script.sh"
Body of "call_ora_script.sh"
#!/bin/sh
PATH=/usr/bin:/usr/local/bin
ORACLE_SID=dbname  #something like this oradb
ORACLE_HOME=/dba00/app/oracle/product/10.1
ORAENV_ASK=NO
. /usr/local/bin/oraenv  # path where oraenv resides
ORAENV_ASK=YES
ORACLE_BIN=$ORACLE_HOME/bin
sqlplus -s /NOLOG << EOF > log.txt
CONNECT username/passwd@dbname
whenever sqlerror exit sqlcode
set serveroutput on size 1000000
set feedback off
set line 200
declare
begin
   dbms_output.put_line('Hello');
end;
@/path/sqlfile_name.sql
@/path/txtfile_name.txt
EXIT
EOF
#To check if the script run fine
x=$?
if [ $x != 0 ] ; then
  echo "error..."
  exit 1
fi
Now execute the script "call_ora_script.sh"
If you want to hide the password, define it in the .profile and use the enviornemt variable in your script.
something like this DB_PASSWD=abc and call it as $DB_PASSWD in your script.
