dkarpekin
two Cisco2811will loose connection to PC(ping- t) behind Cisco2950 , will loose connection
two Cisco2811 by FE0/0 (10.10.200.101 and 10.10.200.102) connected to Cisco2950(10.10.21.100), as well PC (10.10.10.1/15 gaetway10.10.21.100).
Behind both 2811 16port switch(VLan1 witn 10.15.200.1/28 and 10.15.200.16/28) equipment with IP -10.15.200.2 connected to one 2811 16port switch with 10.15.200.1 and 10.15.200.17 connected to one 2811 16port switch with 10.15.200.16.
When I do ping both equipment from PC, it will loose connection periodicly, and can be restored either by "repair" in WinXP or unpluged/reset one of the links to equipments(10.15.200.2 and 10.15.200.17), and bothh will be "online".
When connection is lost to 10.15.200.2/17 and I do "tracert" , instead of showing 2 hops of corrects route, it will show only one hop of the other router, where is no equipment attached.
Looks like 10.15.200.2/17 routs is not hold by 2811, or some other config/IP assigmnet problem.
Please help what is holding me here? Should I separate FE0/0 by subnetting them? Right now ther are Cisco2881#1 FE0/010.10.200.101,Cisco28 81#2 FE0/010.10.200.102,Cisco28 81#3 FE0/010.10.200.103,Cisco28 81#4 FE0/010.10.200.104 all suppose to be connected to Cisco2950 10.10.21.100.
RIP,Ospf,IEGRP disabled and this is "stand-alone" wiring.
VLAN1(16 port switch) on #1 2811 10.15.200.1/28 on 2811 #2 - 10.15.200.16/28 , the are "ip unnumbered async0/0/0"
ip route 10.10.0.0 0.0.0.0 FastEthernet0/0 150
ip route 10.10.0.0 0.0.0.0 Async0/0/0 250
FE0/0 is set as "alternative" to async0/0/0, so when it is plug to LAN it will keep async down( by using150/250 delay set on IP route).
In mine emulation(before deployment), it connected to Cisco 2950(FE0/1, FE0/2+FE0/3 PC plug in).
"loosing connection problem will appear, when I plug second router into 2950, but when there is only one2811, no problem to ping fro PC to 10.15.200.2 or 10.15.200.17.
ACTUAL CONFIG OF "FIELD1"
------------------ show running-config ------------------
Building configuration...
Current configuration : 3057 bytes
version 12.4
no service timestamps debug uptime
no service timestamps log uptime
no service password-encryption
hostname field1
boot-start-marker
boot system flash:c2800nm-adventerpris ek9-mz.124 -6.T6.bin
boot-end-marker
logging buffered 52000 debugging
enable secret 5 <removed>
enable password <removed>
no aaa new-model
resource policy
clock timezone NewYork -5
clock summer-time NewYork date Apr 6 2003 2:00 Oct 26 2003 2:00
ip cef
ip domain name XXXXXXXXX
voice-card 0
no dspfarm
username XXXX privilege 15 secret 5 <removed>
username XXXserver password 0 <removed>
interface FastEthernet0/0
description $ETH-SW-LAUNCH$$INTF-INFO- FE 0/0$$ETH-LAN$
ip address 10.10.200.101 255.255.255.240
ip nat outside
ip virtual-reassembly
duplop enabled
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet1/0
description VPG6000
switchport mode trunk
speed 10
interface FastEthernet1/1
shutdown
- ALL SAME
interface FastEthernet1/14
shutdown
interface F5.0
ip nat inside
interface Async0/0/0
ip unnumbered Vlan1
encapsulation ppp
dialer in-band
dialer string 9,XXXXXXXXXX
dialer string XXXXXXXXXX
dialer-group 1
async mode dedicated
ppp authentication chap pap
routing dynamic
ip route 10.10.0.0 255.255.255.240 FastEthernet0/0 150
ip route 10.10.0.0 255.255.255.240 Async0/0/0 250
ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.15.200.0 0.0.0.255
access-list 189 remark permit PPTP passthrough
access-list 189 remark SDM_ACL Category=2
access-list 189 permit tcp any any eq 1723
access-list 189 permit -server community <removed> RO
control-plane
line con 0
login local
line aux 0
line 0/0/0
script dialer dial
modem InOut
transport input all
transport output all
stopbits 1
speed 115200
flowcontrol hardware
line vty 0 4
privilege level 15
password <removed>
login local
transport input telnet
line vty 5 15
privilege level 15
password <removed>
login local
scheduler allocate 20000 1000
webvpn context Default_context
ssl authenticate verify all
no inservice
end
version 12.4
hostname field1
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip cef
voice-card 0
no dspfarm
ip nat outside
duplop enabled
no ip address
shutdown
duplex auto
speed auto
description VPG6000
speed 10
shutdown
- ALL SAME
shutdown
interface F5.0
ip nat inside
ip unnumbered Vlan1
encapsulation ppp
dialer in-band
dialer-group 1
routing dynamic
ip http server
control-plane
line con 0
login local
line aux 0
line 0/0/0
script dialer dial
modem InOut
transport input all
stopbits 1
speed 115200
line vty 0 4
privilege level 15
password <removed>
login local
line vty 5 15
privilege level 15
password <removed>
login local
no inservice
end
You should not point routes out a broadcast interface (ethernet), you should always use the actual next hop IP address.
Thank you so much, I think you right
Can you also tell me , if I should do the same with ASYNC0/0/0?
This interface will start dialout as soon it will detect traffic trying going out.( if no CAT5 connected on FE0/0).
If I'll use next hop and the only one route
ip route 10.10.0.0 255.255.255.240 10.10.21.100
Will the traffic find the way in both connection - over dialup and over FE0/0 connected to the LAN?
Not necessary for the async interface. You can use the interface as a gateway.
Personally, I do not use ip unnumbered and much prefer to give every interface an IP address. This allows you to keep two route statements for dial on demand routing.
There is suppose to be 4 of remote 2811 to be connected over dialup to server 2811, and will be no need in server2811, if LAN is available on location, and I thought simplefy config by doing "ip unnumbered", as in mine understanding it will assign to async0/0/0 same IP 10.15.200.1 and .16 and .32 and 48 of VlAN1 in "filed1"..-4" and assign async0/0/0 same ip as FE0/0 10.10.21.181 in "server".
Question is, if I'll make:
ip route 10.10.0.0 255.255.255.240 10.10.21.100 150
It should fix mine "posted" problem with loosing connection, but might do the same (loosing connection), when I'll be connected over dialup with "field1" and "field2" 2811. I did not tested this yet, but I think it willhappend ( as there is the same way "point routes out a broadcast interface (ASYNC0/0/0)".
Will it be same problem over async0/0/0 in you opinion?
Async is not a broadcast interface.
So, that why it should not be same problem as with FE0/0 "lossing connection"?, when more than one "field1"..."4 will get connected over dial up to "server"2811 with 4 async WIC -1AM card?
Can you please tell if it will not happend, or if it will happend, what would be the possiblity by%, 70%-99%?
Thanks again for your help.
Thank you. It was greate help.
I will assign /16 subnet to FE0/0 10.10.21.100/16 and should be all set?
I can't answer that because I don't know what all the other subnet masks are.
I think you have some fundamental design issues that you need to really re-think your whole layout, ip assessing scheme and routing for the entire network.
It kind of simple, all network base on Cisco2950(total 12peaces) spreaded throught out country, with one "cetral" 2950 with IP 10.10.10.100/16, to wich is 2950 10.10.21.100/16 , as well all other connected. everything is on static IP/16, all switches is connected by "Marconi" ATM, which makes them same way as they on LAN.
"server"2811 will be behind 10.10.21.100 and provide traffic mostly to PC behind "central"2950 10.10.10.100/16.
All other switches have assigment 10.10.30/40/50/60/70/80... . .100.
Please let me know , if still have pations to review that , all otherwise I think I all set.
Thank you .
Thank you .
If all of your network has /16 mask, then certainly changing the mask on this router to /16 also will make a big difference.
Thank you again.
I will implement those recomendation, and if you dont mind, I'll get back to you 2-3 days later.
Makes no diffrent as was before with original subnetting.
Still loosing connection same way.
Interfaces is /16.
IP route 10.10.0.0 255.255.0.0 10.10.10.100 ( I did change 2950 switch to 10.10.10.100/16)
Now I'm thinking if I should change TTL?
I do have TTL255 to the FE0/0 and TTL63 to the 10.15.200.2 or .17 when I ping them from PC.
And I do suspecting, diffrent TTL is cousing confusion on this small network, as device expararion is shorter than Cisco.Totaly lost right now.........Cisco TAC is lost too.........
Interfaces is /16.
You can't route it to a 2950 l2 switch.
I use to think 2950 is layer3.........but eather way , it is work same way, only diffrent is now ,that with "original' subnetting one of the 10.15.200.2 or .17 will loose connection, and will came back......now they will lose connection at same time fro approx.5-10 min, and they will came back at once................
Loosing connection is meaning of link between PC to 10.15.200.2 .17..........but PC to FE0/0's is stable as well all other "direct" connection- 10.15.200.2 .17 to the port of NM-ESW-16 module.
If you are using /24 mask, how are you routing between the subnets?
How are you routing 10.15.200.0 to 10.10.200.0?
