marchent
fstream read and write problem
i want to write read/write both using fstream, no ifstream/ofstream. here is what i'm trying
string s;
fstream file("test.txt");
file>>s;
cout<<s; //to console
file<<s;
file.flush();
file.close();
it is reading from file, but not writing, can u fix my problem here?
string s;
file>>s;
file<<s;
file.flush();
file.close();
Your last comment does not match your "here is what I'm trying" from original question.
Can you please post EXACTLY what you are trying to do, please :)
I think this what you are looking for, reading and writing file with only one open. Notice the file is opened specifing both input and output.
#include <fstream.h>
int main(int argc, char* argv[])
char s[2046];
fstream file;
file.open("C:\\Test\\Test File 1.txt", ios::out | ios::in);
long beginfile = file.tellp(); // get the beginning of file position
file << "data\n"; // write some data
file << "more data"; // write more data
long endfile = file.tellp(); // get the end of file position
file.flush(); // flush the buffer
file.seekg(beginfile); // go to beginning of file
file.get(s, 5); // read 4 chars and a null into s
cout << s << endl; // print it out
file << s; // write those 4 chars after the four we just read
file.seekg(endfile); // go to what was the end of file
file << s; // write those 4 chars again
file.close(); // close the file
return 0;
The file contents look funky now!
char s[2046];
fstream file;
return 0;
I think my above example has an error in it; you should use seekp (not seekg) to move the "put" pointer. seekg changes the "get" pointer. Sorry!
