Problem with dataset, db2 connection, data adapter when not pulled from tool box
I am trying to verify an insert before executing an Insert to a DB2 table thru a vb.net program.  The code looks like this:
  Private Sub Test_the_insert()
        Dim strSQL2 As String = "Select TC_EMRG_DIAG_CD FROM " & _
            "TCDVLP.TC-EMRG_DIAG_CD WHERE TC_EMRG_DIAG_CD = " & _
            "'" & txtDiagCD.Text & "'"
        Dim cnTestIns As New OleDb.OleDbConnection("Provider=IBMDADB2.1;" & _
        "Mode=ReadWrite;User ID=xxxxxxxx;Data Source=xxxx;Extended Prop" & _
          "erties=;Password=yyyyy")
        Dim daTestIns As New OleDb.OleDbDataAdapter(strSQL2, cnTestIns)
        Dim ds3 As DataSet
        Try
            cnTestIns.Open()
        Catch ex As Exception
            MessageBox.Show("0 " & Convert.ToString(ex.Message))
        End Try
        Try
            daTestIns.Fill(ds3, "Table1")
            cnTestIns.Close()
            cnTestIns.Dispose()
            MessageBox.Show("Insert has data Tested not ok!")
            boolGoodIns = False
            MessageBox.Show("1 " & Convert.ToString(ex.Message))
            MessageBox.Show("An error has occurred!")
        End Try
    End Sub
The program takes the catch path (immediately above)  even when I use a record that has a record already on the table,  So the dataset should not be null.  The funny thing is that when I pull the control from the toolbox, and generate the dataset it seems to work.  When I define it in the program, it doesn't.  I have done mostly the same thing with sql server and oracle.  I just can't see the problem the specific error:
Value cannot be null, parameter name dataset.
When I get past this problem, I plan to test the dataset to see if I returned data, if I did the insert is not allowed, no data means clear to insert.
garyinmiami2003Asked:
Ajay SharmaCommented:
u have to initilize the dataset object.
Dim strSQL2 As String = "Select.........."
        Dim cnTestIns As New OleDb.OleDbConnection(".......")
        Dim ds3 As new DataSet
        Try
            cnTestIns.Open()
        End Try
        Try
            cnTestIns.Close()
            cnTestIns.Dispose()
            boolGoodIns = False
        End Try
    End Sub
http://www-128.ibm.com/developerworks/db2/library/techarticle/0307swart/0307swart.html
momi_sabagCommented:
can you post the output of the program ?
.NET Programming
