I'm trying to play a music CD as usual on my laptop as usual and I getting the message below:
Windows media player cannot play the file because there is a problem with your sound device. There might not be a sound device device installed on your computer, I might be use by another program, or It might not be functioning properly.
I am a HP pavillon dv2000. can you help me sort this problem out, please!!
If so:
I would get the latest windows media player (from microsoft.com) and install it in case of corruption
make sure you have the latest direct x drivers
If not I would go into device manager (windows key + pause/break simultaneously, hardware tab, device manager), drill down to your sound cards and make sure they are functioning properly (no question marks/exclamation marks)
go to HP support website, software and driver downloads, type in the model of notebook and op system and download the audio drivers for installation.
Hope this helps,
Cheers,
Colin
