syswareinc
Problem running remote code from Network drive.
I have application which Encode and image. I have created DLL for this functionality
This DLL is used by Another application. My Problem is...when i create shortcut of this application which reside on Network drive.
I am not able to encode my file. If run application locally am able to achive the functionality.
I am aware about CAS and i have set all the security as FullTrust.
But still am not able to achive it from Network drive. This dll is developed in Framework 1.1
I have set All_Code permission to FullTrust..but its not working...
That's not what I am talking about. You can use the configuration wizard to adjust the Local Intranet Zone to Full Trust.
Bob
Bob
You will achieve same functinality by running wizard. It is one and same thing.
You said "All_Code permission to FullTrust", and that is a different thing.
Bob
Bob
I did it but still now working
I did it but still not working...............
What type of network are you trying to run this from?
Bob
Bob
Intranet
Please be more specific (Linux, Netware, Windows 2003, ...).
Bob
Bob
Windows
I am running this code from Windows XP Professional.
And, the network share is also Windows XP Professional?
Bob
Bob
It is Windows Server 2003
Is the assembly strong named?
Bob
Bob
yes assemblies are strongly named
Bob
