troubleshooting Question
I'm facing problems running eclipse to develope a web application can any body helo in that
Avatar of shang3000
shang3000 asked on
Editors IDEs
3 Comments1 Solution299 ViewsLast Modified:
Hi all,
I'm having fedora core 6 and come with eclipse 3.2 but when working with java server pages projects that have servlets and ejbs I'm facing some problems
1. eclipse closed  unexpectedly and some time show out of memory error (I have 1 GB memory on the laptop box fedora6)
2.when It is closed unexpectedly the tomcat server is opend so the process is lost and it still engaging the port 8080 so to add a new file and test it or to debug the web application I have to restart the machine
3. the version 3.2 is supporting drivers (jdbc driver) for mysql up to version 4.0. how can I add driver in the setting for version 5.00 or later
4. I need a tutorial, links articles  for a creat,update, delete and list records   web application  using jsp and servlets and data connection layer using mysql and J/connector 5 or later using eclipse
can you please help me in that any help, note, idea, link, tutoria, is very appriciatable
best regards
HG
Unlock 1 Answer and 3 Comments.
Learn from the best
Try for 7 days
-Mike Kapnisakis, Warner Bros
