Solved
Power failure caused public store mounting problems
Posted on 2007-07-28
10
Last Modified: 2008-03-10
Ok this is my tuff one for the day.
I am having a bad day... We had a power failure with our SBS 2003 and upon reboot no Exchange 2003 my public store is corrupt and will not mount.
Please let me know if you need more infomation. Also my understanding of SBS is weak so steps will need to be complete. This is realtime and speed is of the upmost importance.
Climato
Question by:icbmlaunch
10 Comments
Author Comment
by:icbmlaunch
C:\Program Files\Exchsrvr\bin>eseutil /MH "C:\Program Files\Exchsrvr\MDBDATA\pri
v1.edb"
Microsoft(R) Exchange Server Database Utilities
Version 6.5
Copyright (C) Microsoft Corporation. All Rights Reserved.
Initiating FILE DUMP mode...
         Database: C:\Program Files\Exchsrvr\MDBDATA\priv1.edb
        File Type: Database
   Format ulMagic: 0x89abcdef
   Engine ulMagic: 0x89abcdef
 Format ulVersion: 0x620,11
 Engine ulVersion: 0x620,11
Created ulVersion: 0x620,9
     DB Signature: Create time:04/12/2007 02:21:21 Rand:4240861 Computer:
         cbDbPage: 4096
           dbtime: 2781183 (0x2a6fff)
            State: Dirty Shutdown
     Log Required: 285-285 (0x11d-0x11d)
   Streaming File: Yes
         Shadowed: Yes
       Last Objid: 811
     Scrub Dbtime: 0 (0x0)
       Scrub Date: 00/00/1900 00:00:00
     Repair Count: 0
      Repair Date: 00/00/1900 00:00:00
 Old Repair Count: 0
  Last Consistent: (0x11D,C32,1D0)  07/28/2007 10:08:58
      Last Attach: (0x11D,C34,41)  07/28/2007 18:27:08
      Last Detach: (0x0,0,0)  00/00/1900 00:00:00
             Dbid: 1
    Log Signature: Create time:04/12/2007 02:21:20 Rand:4217211 Computer:
       OS Version: (5.2.3790 SP 2)
Previous Full Backup:
        Log Gen: 0-0 (0x0-0x0)
           Mark: (0x0,0,0)
           Mark: 00/00/1900 00:00:00
Previous Incremental Backup:
           Mark: (0x0,0,0)
Current Full Backup:
           Mark: (0x0,0,0)
Current Shadow copy backup:
           Mark: (0x0,0,0)
     cpgUpgrade55Format: 0
    cpgUpgradeFreePages: 0
cpgUpgradeSpaceMapPages: 0
       ECC Fix Success Count: none
   Old ECC Fix Success Count: none
         ECC Fix Error Count: none
     Old ECC Fix Error Count: none
    Bad Checksum Error Count: none
Old bad Checksum Error Count: none
Operation completed successfully in 5.156 seconds.
C:\Program Files\Exchsrvr\bin>eseutil /p
Version 6.5
Usage Error: Missing source database specification.
Operation terminated with error -1003 (JET_errInvalidParameter, Invalid API para
meter) after 0.188 seconds.
C:\Program Files\Exchsrvr\bin>eseutil /p "C:\Program Files\Exchsrvr\MDBDATA\priv
1.edb"
Version 6.5
Initiating REPAIR mode...
  Streaming File: C:\Program Files\Exchsrvr\MDBDATA\priv1.STM
  Temp. Database: TEMPREPAIR4376.EDB
Checking database integrity.
The database is not up-to-date. This operation may find that
this database is corrupt because data from the log files has
yet to be placed in the database.
To ensure the database is up-to-date please use the 'Recovery' operation.
                     Scanning Status (% complete)
          0    10   20   30   40   50   60   70   80   90  100
Integrity check successful.
Note:
  It is recommended that you immediately perform a full backup
  of this database. If you restore a backup made before the
  repair, the database will be rolled back to the state
  it was in at the time of that backup.
Operation completed successfully with 205 (Unknown Error, Unknown Error) after 4
5.63 seconds.
C:\Program Files\Exchsrvr\bin>eseutil /d "C:\Program Files\Exchsrvr\MDBDATA\priv
1.edb"
Version 6.5
Initiating DEFRAGMENTATION mode...
      Temp. Database: TEMPDFRG1740.EDB
Temp. Streaming File: TEMPDFRG1740.STM
                  Defragmentation Status (% complete)
Moving 'TEMPDFRG1740.EDB' to 'C:\Program Files\Exchsrvr\MDBDATA\priv1.edb'... DO
NE!
Moving 'TEMPDFRG1740.STM' to 'C:\Program Files\Exchsrvr\MDBDATA\priv1.stm'... DO
NE!
Note:
  defragmentation, the database will be rolled back to the state
Operation completed successfully in 60.922 seconds.
1.edb"
Version 6.5
  Temp. Database: TEMPREPAIR1188.EDB
Note:
Operation completed successfully with 205 (Unknown Error, Unknown Error) after 1
8.672 seconds.
Author Comment
by:icbmlaunch
this should help!
LVL 13
Assisted Solution
by:bluetab
bluetab earned 600 total points
I'm assuming that you don't have a recent backup of your server and Exchange.  And you've done the most logical troubleshooting steps already.  So at this point I would highly recommend calling Microsoft Tech Support.  The cost is $245 but they will walk you through all the steps of getting the problem resolved or exhaust all options trying.  I've called them about this type of stuff before and it's well worth the money.
http://support.microsoft.com/oas/default.aspx?ln=en-us&x=8&y=14&prid=6001&gprid=35178
Author Comment
by:icbmlaunch
C:\Program Files\Exchsrvr\bin>Eseutil /ml "C:\Program Files\Exchsrvr\MDBDATA\E00
.log"
Version 6.5
      Base name: E00
      Log file: C:\Program Files\Exchsrvr\MDBDATA\E00.log
      lGeneration: 285 (0x11D)
      Checkpoint: NOT AVAILABLE
      creation time: 07/28/2007 05:02:55
      prev gen time: 07/27/2007 05:12:56
      Format LGVersion: (7.3704.8)
      Engine LGVersion: (7.3704.8)
      Env SystemPath: C:\Program Files\Exchsrvr\mdbdata\
      Env LogFilePath: C:\Program Files\Exchsrvr\mdbdata\
      Env Log Sec size: 512
      Env (CircLog,Session,Opentbl,VerPage,Cursors,LogBufs,LogFile,Buffers)
          (     on,    252,  12600,   1741,  12600,    500,  10240, 147456)
      Using Reserved Log File: false
      Circular Logging Flag (current file): on
      Circular Logging Flag (past files): on
      1 C:\Program Files\Exchsrvr\mdbdata\priv1.edb
        dbtime: 2780524 (0-2780524)
        objidLast: 811
        MaxDbSize: 0 pages
        Last Attach: (0xFE,1C1C,1C8)
        Last Consistent: (0xFE,1C1B,157)
      2 C:\Program Files\Exchsrvr\mdbdata\pub1.edb
        dbtime: 2586018 (0-2586018)
        objidLast: 1598
        Signature: Create time:04/12/2007 02:21:21 Rand:4208034 Computer:
        MaxDbSize: 0 pages
        Last Attach: (0xFE,1C1D,B1)
      ERROR: Log damaged (unusable). Last Lgpos: (0x11d,C35,0). Error -501.
Operation terminated with error -501 (JET_errLogFileCorrupt, Log file is corrupt
) after 4.203 seconds.
LVL 23
Expert Comment
by:Stacy Spear
Why didn't you use the recovery mode /R ?
darkstar3d
LVL 9
Accepted Solution
by:
sguinn100 earned 800 total points
If you have a good backup, this might help ~
http://support.microsoft.com/kb/823016/en-us
If you don;t have a good backup, try this ~
http://www.msexchange.org/tutorials/Exchange-ISINTEG-ESEUTIL.html
Author Comment
by:icbmlaunch
darkstar3d,
this is what happens:
C:\Program Files\Exchsrvr\MDBDATA>"C:\Program Files\Exchsrvr\bin\Eseutil" /r E00
Version 6.5
Initiating RECOVERY mode...
    Logfile base name: E00
            Log files: <current directory>
         System files: <current directory>
Performing soft recovery...
Operation terminated with error -1032 (JET_errFileAccessDenied, Cannot access fi
le, the file is locked or in use) after 21.219 seconds.
i tryed earler before
1.edb"
Author Comment
by:icbmlaunch
Event Type:      Error
Event Source:      ESE
Event Category:      General
Event ID:      490
Date:            7/29/2007
Time:            2:54:26 PM
User:            N/A
Computer:      ********
Description:
Information Store (3444) First Storage Group: An attempt to open the file "C:\Program Files\Exchsrvr\mdbdata\E00.chk" for read / write access failed with system error 5 (0x00000005): "Access is denied. ".  The open file operation will fail with error -1032 (0xfffffbf8).
For more information, click http://www.microsoft.com/contentredirect.asp.
LVL 23
Assisted Solution
by:Stacy Spear
Stacy Spear earned 600 total points
Stop your exchange services and try again.
Author Comment
by:icbmlaunch
thanks for your help!
VIDEO: THE CONCERTO CLOUD FOR HEALTHCARE
Modern healthcare requires a modern cloud. View this brief video to understand how the Concerto Cloud for Healthcare can help your organization.
With so many activities to perform, Exchange administrators are always busy in organizations. If everything, including Exchange Servers, Outlook clients, and Office 365 accounts work without any issues, they can sit and relax. But unfortunately, it…
Steps to fix error: “Couldn’t mount the database that you specified. Specified database: HU-DB; Error code: An Active Manager operation fail”
In this video we show how to create a mailbox database in Exchange 2013. We show this process by using the Exchange Admin Center. Log into Exchange Admin Center.: First we need to log into the Exchange Admin Center. Navigate to the Servers >> Data…
There are cases when e.g. an IT administrator wants to have full access and view into selected mailboxes on Exchange server, directly from his own email account in Outlook or Outlook Web Access. This proves useful when for example administrator want…
Suggested Courses
840 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
