troubleshooting Question
Difference between a set top box and a DVD recorder with a HDD and TV Tuner.
Avatar of Marina2006
Marina2006 asked on
Home Theaters
2 Comments1 Solution450 ViewsLast Modified:
I seem to be getting lost in the spec detail can anyone tell me what the difference between a set top box and a DVD recorder with a HDD (besides burning discs of course).
Unlock 1 Answer and 2 Comments.
Learn from the best
Try for 7 days
-Mike Kapnisakis, Warner Bros
