butterhook
Strange Vista MSI installation problem... executes small part of contents, doesn't install
I have a strange problem with an MSI installer that I have made for my application (A COM addin for MS Word and an executable video player ). When I install on Windows XP everything is fine, but..
When I run the MSI within Windows Vista, one small .exe file runs from within it but the actual installer does not run. I need to install the application on this computer, and have done so on Vista before.
What is the problem? How can I solve it? Please help!
Can you try this work around to see if it allows you to do the install..
Temporarily disable User Account Control (UAC). With UAC disabled the installation may work the normal way by double-clicking on the MSI file. To disable UAC, search for the phrase "turn off UAC" from the Vista help window and follow the directions. You will need to reboot Vista after changing this setting. If the installation is complete, you can turn UAC back on.
@mirtheil - I used the Visual Studio Installer package (from Visual Studio 6) to create the installer
@lyonst - I had the UAC off already.
- How was the MSI generated (InstallSHield, Wise, Wix, etc)?
- What's in the MSI Log? Here's an article on how to enable logging: http://support.microsoft.com/kb/223300
- How are you running the MSI?
