System Volume Info on Flash Drive
I have an old flash drive that I am cleaning everything off of.
It has two folders left: Recycled and System Volume Information.
I emptied the Recycle folder, no problem.
The system volume information folder has five sub-folders, each with a label like:
_restore{B7AB23D2-A75C-43C4-91EF-27C44CBD93F4}
What are these folders, and do I need to keep them.
Tomster2
Tomster2
  • 2
3 Solutions
rindiCommented:
They store system states. It doesn't make much sense too keep those on all drives. You can delete everything on that drive if you boot with a UBCD4WIN or knoppix.
http://ubcd4win.com
http://knoppix.net
You could also turn off system restore on that drive by right clicking "My Computer", selecting "Properties", then "System Restore". Just don't turn it off for the main drives.
456838Commented:
it is a protected file and just make sure you check the
"hide operating system file" in tool----> folder option---> view
then u may neglect it.. it wont consume alot of space  ;)
nobusCommented:
just format the drive to clean everything off !
456838Commented:
any updates for this case ?
We value your feedback.
  • 2
