Internet connection drops after 10 seconds using broadband or wireless connection
Acer laptop approx 5 years old. Windows XP SP2 with all updates.
Problem - the internet connection drops after around 10 seconds, consistently after each connection. This happens on both wireless connections (tested 3 different) and wired broadband connection to BT modem. On wireless windows wireless networking notes the  dropped connection and tries to reconnect but this is periodic and not after the 10 second cutoff. On broadband windows does not register the dropped connection - icon is still present on taskbar. On wireless LAN other computers can still access shared folders on this laptop and trasfer files to and from successfully. Laptop however cannot 'see' other computers on network once internet connection dropped.
Please can someone provide a solution to rectify this problem. Many thanks.
tomtolkien
tomtolkien
SysExpertCommented:
Check  for malware and also try doing a TCPIP reset.
XP TCPIP fixes reset NIC and TCPIP
What I like to do on any network problem....Is to reset it ALL....
netsh int ip reset reset.log
netsh firewall reset
netsh winsock reset
Then remove ALL NIC's from the device manager..
In the Device Manager, select View>Show Hidden Devices
(If the Show Hidden devices is not presetn, do the following command from a command prompt..)
start>run>cmd
set devmgr_show_nonpresent_devices=1
More information on that command here....
Device Manager does not display devices that are not connected to the Windows XP-based computer
http://support.microsoft.com/kb/315539
Go back to Network Adapters, and make sure your adapters are all gone, including any older ones. (there will be several ' miniport' devices that are not able to be uninstalled....)
Once they are all gone, reboot and let Windows reinstall them...
Thats a total rebuild of your network connections, to hopefully correct any problems with Basic connectivity.
I hope this helps !
ocantrellCommented:
try at St. Francis on Dell laptops
Efficient way to get backups off site to Azure
This user guide provides instructions on how to deploy and configure both a StoneFly Scale Out NAS Enterprise Cloud Drive virtual machine and Veeam Cloud Connect in the Microsoft Azure Cloud.
