TeraStation Pro - Firmware and access Issues - Buffalo no help!!
soupy28
soupy28 asked
on
Last Modified: 2013-12-02
My Terastation Pro has been working like a charm for about 8 months. Without having changed anything, this morning it did not register as a network drive and was not accessible via browser management. There is no obvious disk failure (all disk LEDs are green). The Terastation boots normally. The LCD does not show the firmware version but displays something like =========. I can ping the Terastation and it responds. The client utility shows me that the name of the station has been set back to TS-TGL-EM from the name I had given it. The client utility further shows me that the Terastation is not part of a workgroup (it was until yesterday) and has no firmware (it shows ----- where usually the firmware version is displayed). I can not access the Terastation via webbrowser. As the thing was packed with data ( approx 1.4 Gig) I would very much appreciate any advise on how I can access the unit. I have contacted Buffalo, and like all other vendors, they were of no help at all. I have a second Terastation and my idea was to simply put all 4 drives from the one into the other to at least have the possibility to backup the data to a file server. Will that work or am I going to ruin my second Terastation as well? Need HELP on this ASAP. Thanks so much, Soupy
Watch Question
Top Expert 2007
I would escalate at Buffalo until this is resolved.
Is it still under  warranty ?
Yes, you might be able to swap out the drives, since  would hope that the firmware is embedded in the hardware and not the drives.
I would also wait for someone with more terstation experience.
I hope this helps !
Top Expert 2007
also see
https://www.experts-exchange.com/OS/Miscellaneous/Q_22652440.html
Also recheck the install manual and see if there is any kind of way to do a manual reset of the built in firmware.
I called in a Linux expert and he was able to restore the firmware on both devices. Of course what he did will remain a big secret as he isn't telling... No matter to me though, as I was able to retrieve all of the data and end the crisis.
Top Expert 2007
Good to know.
So Buffalo support was not stellar...
I love their hardware, but like just about every other vendor out there, the tech support leaves a lot to be desired.
hey soupy, i had this EXACT same problem :( i was wondering how
hey sorry about the above post, its my first time :)
i was just asking soupy how i could "call in a linux expert" to resolve my situation?
i have encountered the EXACT same problem :( please PLEASE help!
djbono11:
We found a software package on the Buffalo site that allows you to reflash the drive. Look for the following:     TSPro-1.01-0.51-withAD.zip
It is a zip file with a Read Me file, follow the instructions in the Read Me, and it "should" work....
This one is on us!
(Get your first solution completely free - no credit card required)
UNLOCK SOLUTION
chops_uk - your solution worked. Thanks.
I didn't need to add the following two lines to the nasupdater.ini
[SpecialFlags]
Debug=1
I used a newer version of the firmware.
Gain unlimited access to on-demand training courses with an Experts Exchange subscription.
Get Access
Why Experts Exchange?
Experts Exchange always has the answer, or at the least points me in the correct direction! It is like having another employee that is extremely experienced.
Jim Murphy
Programmer at Smart IT Solutions
When asked, what has been your best career decision?
Deciding to stick with EE.
Mohamed Asif
Technical Department Head
Being involved with EE helped me to grow personally and professionally.
Carl Webster
CTP, Sr Infrastructure Consultant
Empower Your Career
Did You Know?
We've partnered with two important charities to provide clean water and computer science education to those who need it most. READ MORE
Ask ANY Question
Connect with Certified Experts to gain insight and support on specific technology challenges including:
  • Troubleshooting
  • Research
  • Professional Opinions
Join our community and discover your potential
Experts Exchange is the only place where you can interact directly with leading experts in the technology field. Become a member today and access the collective knowledge of thousands of technology experts.
OR
Please enter a first name
Please enter a last name
