AndyAinscow
Multi-monitor problem with CRect and CPoint
I've just been alerted to some wierd behaviour (bug in op system / MFC code ?)
I have a user that has a two monitor system (in Europe) and, for some reason, has the primary monitor defined as the monitor on the right and the secondary monitor is on the left. So the system thinks the top left of the primary monitor is 0, 0
This, of course, means the co-ordinates on the left hand monitor are 'strange'.
I am performing a hit test on a control drawn into the NC area of an edit box. It isn't responding to the mouse. basically return rectButton.PtInRect(ptTest );
rectButton is a CRect and ptTest is a CPoint.
The value in ptTest has an x-co-ordinate of 64786 and in the rectButton the l, r is -761, -744
So the PtInRect call is failing - despite the mouse being in the rectangle the return is false.
Is there a flag/function to make it compare the signed/unsigned values correctly or do I have to code some sort of hack?
I think the problem is the CPoint and CRect are using LONG variables internally.
I suspect I am going to have to do a hack.
Oh bleep
CPoint(GET_X_LPARAM(lParam ),GET_Y_LP ARAM(lPara m)))
ASSERT(::IsWindow(GetSafeH
if(!IsButtonVisible())
return FALSE;
CRect rectButton=CalcButtonRect(
ClientToScreen(rectButton)
AND
CRect CMyEdit::CalcButtonRect() const
CRect rect(0,0,0,0);
if(IsButtonVisible())
GetClientRect(rect);
rect.left=rect.right;
rect.right=rect.left+GetBu
return rect;
AND in the WindowProc of the custom edit
LRESULT CMyEdit::WindowProc(UINT message, WPARAM wParam, LPARAM lParam)
case WM_NCLBUTTONDOWN:
LRESULT lResult=CEdit::WindowProc(
if(!IsWindowEnabled() || (GetStyle()&ES_READONLY))
return lResult;
if(HitButtonTest(CPoint(LO
