ml1n4
Is there such a thing as a "low temperature" laser printer? (to prevent ink ghosting)
Hi there,
I've recently had a bunch of letter heads printed using a digital printing process. Upon using them in my laser printer, the ink is being melted onto the drum / roller and the transferred as a ghosted image down the page. I'm reliably informed that this is the problem with using lasr printers with such materials.
My question then is this; is there such a thing as a laser printer that operates at temperatures low enough to prevent such an ink re-melting / transfer issue? And if so, who makes this wonderful machine?
Thanks in advance.
Matt
Thanks in advance.
Matt
BTW, with solid ink printers the paper never gets any hotter than about 80 C, compared to around 150 C for a laser. The ink melts at around 90 C.
I would agree about returning the paper to the supplier as it is not fit for purpose, however, I had them done as a favour so I think I'll have to live with it... :-)
Thanks for the help guys.
p.s. I would love a solid ink printer - they are clearly the future for environmentally conscious businesses!
Your welcome! I'm glad I could help. Thanks for the fun question, the grade and the points.
bol
bol
One thing you might try is to set up a template in Word for your letterhead and print the letter and the letterhead in one pass.
Of course if you wanted color letterhead and you only have a black laser, you are out of luck.
-K
-K
