Avatar of Patrick Miller
Patrick MillerFlag for United States of America
Problem with Cisco Wireless AP using Aironet 1310 and mast antenna connecting to bridge AP
I have a 1310 Aironet AP with AIR-ANT24120 mast located in the middle of my complex (outdoor on a pole 50ft up).  I was able to get it connected to the 1310 Aironet AP bridge at a sales office with clear line of site at 1000 ft 15 ft up on roof.  All that seems to work fine.  The problem I am having is Standing directly under the mast or even within 100 ft from it I do not get a signal.   Will this mast just help me with the long distance connection.  Am I going to have to put another AP in play right next to it for the shorter distances?   Did I buy the wrong mast?  I am trying to have access across most of my outdoor complex for wireless barcode scanners and stil be able to connect from the sales lot 1000 ft away.  Any suggestions.   Should I change my directional AP bridge on the sales lot to Wireless access?  Any help would be welcome.
Avatar of jekl2000
jekl2000
As the dbi of an antenna increases, the radiating signal gets smaller close to the antenna and as it moves away it starts gaining vertically and horizontally. You are most likely overshooting everything below. Because of the vertical height of the signal at 1000 feet, you could probably down tilt the antenna to put more signal closer to the ground or get a lower dbi antenna or as you said get another AP for the localized area. This is a normal situation.
Would I be ok putting the localized AP on the same pole?  Can I get a setup that would handle bridging and Wireless?
Avatar of jekl2000
jekl2000
See answer
