Cisco 2600 NAT problem with Cable Modem Ethernet to Ethernet connection
I have a Cisco 2620 IOS 12.3 with the 4 port Ethernet card on the back. I am using interface Ethernet1/0 for a cable modem with a cidr block. I cannot get the NAT pool to work correctly to allow external addresses to pass through to the internal network. Here is my configuration
Current configuration : 3075 bytes
version 12.3
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname c3
enable secret 5 $1$DaAt$XD7X7MK42wCsZ6Gf0xUe2.
enable password cisco
ip subnet-zero
ip inspect dns-timeout 30
ip inspect name Firewall ftp
ip inspect name Firewall tcp
ip inspect name Firewall udp
ip inspect name Firewall h323
ip audit notify log
ip audit po max-events 100
no voice hpi capture buffer
no voice hpi capture destination
interface FastEthernet0/0
 ip address 192.168.50.50 255.255.255.0
 ip nat inside
 speed auto
 full-duplex
 description COX Business Internet
 ip address 70.167.224.18 255.255.255.240 secondary
 ip address 70.167.224.17 255.255.255.240 secondary
 ip address 70.167.224.20 255.255.255.240 secondary
 ip address 72.215.221.240 255.255.255.224
 ip access-group 101 in
 no ip redirects
 no ip unreachables
 ip accounting output-packets
 ip nat outside
 ip inspect Firewall in
 ip inspect Firewall out
 half-duplex
 no cdp enable
interface Ethernet1/1
 no ip address
 shutdown
 half-duplex
interface Ethernet1/2
 no ip address
 shutdown
 half-duplex
interface Ethernet1/3
 no ip address
 shutdown
 half-duplex
ip default-gateway 72.215.221.225
ip nat pool NATPOOL 70.167.224.18 70.167.224.30 netmask 255.255.255.240
ip nat inside source list 1 interface Ethernet1/0 overload
ip nat inside source route-map NATMAP pool NATPOOL overload
ip nat inside source static tcp 192.168.50.20 80 interface Ethernet1/0 80
ip nat inside source static 192.168.50.20 70.167.224.20
ip nat inside source static tcp 192.168.50.20 80 70.167.224.20 80 extendable
no ip http server
no ip http secure-server
ip classless
ip route 0.0.0.0 0.0.0.0 72.215.221.225
access-list 1 permit 192.168.50.0 0.0.0.255
access-list 101 deny   ip 127.0.0.0 0.255.255.255 any
access-list 101 deny   ip 224.0.0.0 0.255.255.255 any
access-list 101 deny   ip 10.0.0.0 0.255.255.255 any
access-list 101 deny   ip 172.0.0.0 0.255.255.255 any
access-list 101 deny   ip 192.0.0.0 0.255.255.255 any
access-list 101 deny   ip host 0.0.0.0 any
access-list 101 deny   icmp any any redirect
access-list 101 permit icmp any any administratively-prohibited
access-list 101 permit icmp any any echo
access-list 101 permit icmp any any packet-too-big
access-list 101 permit icmp any any time-exceeded
access-list 101 permit icmp any any unreachable
access-list 101 permit icmp any any echo-reply
access-list 101 permit tcp any host 72.215.221.240 eq www
access-list 101 permit tcp any host 72.215.221.240 eq 443
access-list 101 permit tcp any host 72.215.221.240 eq ftp
access-list 101 permit tcp any host 72.215.221.240 eq 59002
access-list 101 permit tcp any host 70.167.224.20 eq www
access-list 101 permit tcp any host 70.167.224.20 eq 443
access-list 101 permit tcp any host 70.167.224.20 eq 444
access-list 101 permit tcp any host 70.167.224.20 eq smtp
access-list 101 permit tcp any host 70.167.224.20 eq 3389
line con 0
line aux 0
line vty 0 4
 login
end
Here is my info from the ISP
IP Assignment
Subnet Detail
Customer Network         70.167.224.16/28
Customer NetMask        255.255.255.240
Number of hosts            13
Suggested Default Gateway        70.167.224.17
First Useable     70.167.224.18
Last Useable     70.167.224.30
Broadcast         70.167.224.31
WAN Address   72.215.221.240
WAN Netmask 255.255.255.224
WAN Gateway   72.215.221.225
DNS:
68.13.16.30
68.13.16.25
Any help on what I have missed would be greatly appreciated
danej256
danej256
  • 2
trinak96Commented:
I think the problem is on your access-list 101. You are not allowing traffic onto the LAN subnet.
lrmooreCommented:
1) you don't need the secondary addressing on the interface
2) you have competing static nat statements to same inside host. Pick one of the three:
I would pick the middle one and remove the other two.
3) remove the default-gateway command. Your ip route 0.0.0.0 statement is what you need to keep.
 no  ip default-gateway 72.215.221.225
4) The IP that you are trying to use as a static is also in the middle of your pool:
 ip nat pool NATPOOL 70.167.224.18 70.167.224.30  <== overlaps with .20
Suggest changing the pool to not include .20
  ip nat pool NATPOOL 70.167.224.21 70.167.224.30
danej256Author Commented:
I have a working config that I started to base all this off of that had everything working based off the access lists that I have in place now althoiugh it was set up for a Frame Relay.  Also lrmoore I have tried everything you suggested and I am still not having any luck.
 It may very well be something else missing from the access list but I am not sure what to put in there.
lrmooreCommented:
  ip inspect Firewall in <== remove this.
You don't need to inspect both directions.
Does Cox route the secondary block of IP addresses to you via this WAN ip address? It would be un-typical of your block of IP's to be different than the subnet assigned to the interface.
Big Data Means Big Business
In data-dependent industries like IT, finance, and healthcare, there’s a growing demand for qualified analysts to fill leadership roles. WGU’s MS in Data Analytics has IT certifications from Oracle and SAS built into its curriculum at a flat fee that could save you money.
  • 2
