using system.drawing does not load
I am very new to C# and am having a problem with using Graphics...  I am creating a component for a traffic light, and can not using Graphics because I cannot load System.Drawing. When I type in using system.
the drawing option does not appear... what am I doing wrong?
brassmonAsked:
surajgupthaConnect With a Mentor Commented:
right click ur project-> add reference -> choose .net -> look for system.drawing
surajgupthaCommented:
Make sure you are typing using above the namespace tag?
using System.Drawing;
namespace EE.Questions.C#
Which project are you trying to type using in? web /windows/ services ??
brassmonAuthor Commented:
I am typing above the namespace.. and all of the other namespaces are working fine...
I'm not sure what you mean by your question.. I'm writing a windows program..
when I type using system.    why would drawing not show up in the list of choices?
Try adding System.Drawing into the references
