Need help with a left join in a sql for paid and unpaid invoices in Oracle Payables
Trying to include invoices that are open or only partially paid in a query that now shows only paid invoices. This is my current sql and despite the left joins, it doesn't output any invoices known to be unpaid
select hou.name operating_unit
    ,pv.vendor_name
    ,pv.segment1 vendor#
    ,ac.check_number check#
    ,ac.check_date
    ,ac.amount check_Amt
    ,ai.invoice_num Inv#
    ,ai.invoice_date
    ,ai.invoice_amount Inv_Amt
    ,sum(ai.invoice_amount - ai.amount_paid) bal_open
from ap_checks_all ac
    join ap_invoice_payments_all aip
        on ac.check_id = aip.check_id
    join hr_operating_units hou
        on ac.org_id = hou.organization_id
    left join ap_invoices_all ai
        on ai.invoice_id = aip.invoice_id
        and ai.cancelled_date is null
    left join po_vendors pv
        on pv.vendor_id = ac.vendor_id
        and pv.vendor_id = ai.vendor_id
    where ac.void_date is null
and trunc(ai.invoice_date) >= '01-JAN-06'
    and pv.segment1 in ('33115','4597','27865')
group by hou.name
    ,pv.vendor_name
    ,pv.segment1
    ,ac.check_number
    ,ac.check_date
    ,ac.status_lookup_code
    ,ac.amount
    ,ai.invoice_num
    ,ai.invoice_date
    ,ai.invoice_amount
    ,ai.amount_paid
    ,aip.amount
    ,aip.accounting_date
janthonyn
janthonyn
  • 8
  • 6
  • 4
  • +2
2 Solutions
dqmqCommented:
Probably because this line does not test true with nulls in invoice_date:
try replacing it with:
and (ai.invoice_date IS NULL or trunc(ai.invoice_date) >= '01-JAN-06')
Guy Hengel [angelIII / a3]Billing EngineerCommented:
this is primarily because you had a WHERE clause with conditions on the columns of those tables you have left joined to, which makes it implicitely a inner join...
the remark of dqmq might be helpful also, you might want to integrate it also, if the below is not enough
    ,pv.vendor_name
    ,ac.check_date
    ,ai.invoice_date
group by hou.name
    ,pv.vendor_name
    ,pv.segment1
    ,ac.check_number
    ,ac.check_date
    ,ac.amount
    ,ai.invoice_num
    ,ai.invoice_date
    ,ai.invoice_amount
    ,ai.amount_paid
    ,aip.amount
dqmqCommented:
AngelIII is right, I didn't solve the whole problem.  Exactly the same issue (about not testing true with the nulls resulting from a left join) applies to pv.segment1. So you need to do this
and ( pvs.segment1 is null or pv.segment1 in ('33115','4597','27865'))
We value your feedback.
janthonynAuthor Commented:
So far nothing you suggest has worked. Haven't figured out why, but here's a question. Why would any invoice_date or vendor number (pv.segment1)  be null? What I need is for records with null check_dates to return
please change this:
into:
        and ai.invoice_date >= TO_DATE('01-JAN-06', 'DD-MON-YY')
Here is what my query looks like now and I'm still not seeing any non-paid invoices:
    ,pv.vendor_name
    ,to_char(ac.check_date,'DD-MON-YY') chk_dt
    ,ai.invoice_num inv#
    ,ai.invoice_date inv_dt
    ,ai.invoice_amount inv_amt
        on ai.org_id = hou.organization_id
--and ac.check_date is null or trunc(ac.check_date) >= '01-JAN-06'
  and ai.invoice_date >= to_date('01-JAN-06','DD-MON-YY')
group by hou.name
    ,pv.vendor_name
    ,pv.segment1
    ,ac.check_number
    ,ac.check_date
    ,ac.amount
    ,ai.invoice_num
    ,ai.invoice_date
    ,ai.invoice_amount
    ,ai.amount_paid
I think, we need to find out now, how do you identify unpaid invoices (in plain english).
It all has to do with if a check or wire has been processed for a certain invoice, thus establishing an association with an invoice_id and corresponding payment.
how do you identify that, speaking column names and values?
dqmqCommented:
Because you did an outer (left) join, which means that ify you have a payment or a check without an invoice you get nulls for the invoice columns and the vendor columns.  On second thought, that DOES sound silly, so I think maybe the problem is that you are using the wrong kind of join.
Try this:
    ,pv.vendor_name
from  ap_invoices_all ai
  left join ap_invoice_payments_all aip
  left join ap_checks_all ac
  left join hr_operating_units hou
        on pv.vendor_id = ai.vendor_id
    and trunc(ac.check_date) >= '01-JAN-06'
    and (pv.segment1 in ('33115','4597','27865') or pv.segment1 is null)
group by hou.name
    ,pv.vendor_name
    ,pv.segment1
    ,ac.check_number
    ,ac.check_date
    ,ac.amount
    ,ai.invoice_num
    ,ai.invoice_date
    ,ai.invoice_amount
    ,ai.amount_paid
dqmq,
Your sql is closer to the right answer. It output fully paid and partially paid invoices with the associated checks. But I'm still looking for invoices with no checks whatsoever. There are many of those. Open invoices. With nothing paid on an invoice, there are no records in the ap_checks_all table.
dqmqCommented:
So, we've come 'round-about to my first advice.   Basically, if a field is null, you have to test for that condition explicitly--none of the comparison operators yield true or false when one of the operands is null.
Try this:
    ,pv.vendor_name
    and (trunc(ac.check_date) >= '01-JAN-06' or ac.check_date is null)
group by hou.name
    ,pv.vendor_name
    ,pv.segment1
    ,ac.check_number
    ,ac.check_date
    ,ac.amount
    ,ai.invoice_num
    ,ai.invoice_date
    ,ai.invoice_amount
    ,ai.amount_paid
Thanks for this latest attempt. Still not getting records without checks. All unpaid invoices for these vendors are missing from the query output.
dqmqCommented:
OK, let's see if I have this straight.  You have records in ap_invoices_all table that are not showing up in the results. Is that correct?
Now, I suggest temporarily commenting out a couple of the conditions to see if the invoices show up.
where
--    and ai.cancelled_date is null
--    and (pv.segment1 in ('33115','4597','27865') or pv.segment1 is null)
dqmq
The invoices that aren't paid aren't cancelled, so commenting out the ai.cancelled_date is null condition won't get to the problem with the joins. The pv.segment1 column is the vendor number column and restricts the query to those vendors.
dqmqCommented:
I don't think there is a problem with the joins.  Really, given all the left joins, the only possibility remaining is that vendorid is not the right column to join on.  There's little left besides the "where clause" to explain why you are not seeing the records.  I mean, with all those left joins, every invoice should display except those excluded by the where conditions. So, I just want to rule out the possibility that either of those conditions is having unintended/unexpected results.
If you like, we can start small and build up. Does this return the invoices you are looking for:
select
     pv.vendor_name
where
group by
     pv.vendor_name
    ,pv.segment1
    ,ai.invoice_num
    ,ai.invoice_date
    ,ai.invoice_amount
    ,ai.amount_paid
If no, then fix the where conditions.
If yes, then add a left join to one table at a time (gradually building up to your desired query) until they disappear.  That process should help you hone in on the problem.
I have a hunch that the problem this query has eminates from not having included the ap_invoice_sites_all table. I will try adding a left join with this table. Also, someone told me that Oracle syntax uses the words "LEFT OUTER JOIN" and doesn't work well when using just "LEFT JOIN". I'm going to try both changes and see what gives.
Split is OK. Please close this ticket. I'll keep searching for an answer.
Computer101Commented:
Forced accept.
Computer101
EE Admin
anandagrawal444Commented:
 Here the objective of the user is to find the unpaid and partially paid invoices. For this he is joining so many tables. Actually this objective can be achieved only through a single table AP_Invoices_All. This table is having the columns for invoice amount as well as the amount paid. So the desired result can be directly retrieved from this table.
For retrieving vendor details, PO_vendors can be used.
Free Tool: Path Explorer
  • 8
  • 6
  • 4
  • +2
