Snag-it program locking up on system "Snag-it encountered a problem dialog problem."
Snag-it program ver 8.2 locking up user's PC. Comes up with dialog box that "Snagit encountered a problem and needs to close." User has Radeon 9250 Video cards.
techscott2007
techscott2007
  • 2
  • 2
VorenusCommented:
Is DEP (Data Execution Prevention) enabled ?
Start -> Run
sysdm.cpl
The System Properties dialog appears
Click on the "Advanced" Tab
Click on Settings button belonging to the "Performance" frame.
Then Click the "Data Execution Prevention" tab.
Try disabling it, completely first, and if it works, switch it back on and add an exception for SnagIt only.
I already had problems with SnagIT and turning off DEP for it fixed the problems.
techscott2007Author Commented:
DEP is set for programs and settings only. How can you disable it?
I did change the Settings from Custom in advanced to Let windows choose whats best for my PC and it flashed the sceens for about 15 seconds, and it's working so far.
VorenusCommented:
Click on the second button and add the exception for SnagIT related programs.
will do thanks for the quick response Vorenus.
 The Evil-ution of Network Security Threats
What are the hacks that forever changed the security industry? To answer that question, we created an exciting new eBook that takes you on a trip through hacking history. It explores the top hacks from the 80s to 2010s, why they mattered, and how the security industry responded.
  • 2
  • 2
