Solved
Power Mac G4 Quick Silver (digital audio model  M7627-M7688-M7945-M7681) Power wont stay on.
Posted on 2007-11-15
Last Modified: 2013-11-24
The above Mac Model Number which is one.  All use the same design and parts I am told.  Just audio is different.
I push the button and the fan only runs for a second and the light on the front case goes out and the small light on the motherboard goes out.  It wont stay running.\
I replaced the battery, replaced the memory and just went down to one memory stick in each slots.  Pulled the battery and reset the pmu button and left machine off with battery out for a day.  inserted the battery again and left it in for half hour before starting and pluging in the machine.  The same thing exist.
any suggestions
thanks
Question by:Georgeidp
1 Comment
LVL 19
Accepted Solution
by:
pheidius earned 2000 total points
The best case scenario is that your PS has died. The bad side is that a new PS for a DA  is worth more then an entire
bare bones DA on Ebay.  I guess you gotta look at how much you have invested in upgrades for your Da. I have one with a raid card, multiple big pata drives,  a dual 1.4 upgrade,  a  flashed 6800 gt, and a fire wire PCI card. If mine was doing that I would probably just buy a guaranteed no doa bare bones case. but you can check it for yourself. There is a MB for 24 bucks right now on ebay plus several power supplies plus a bunch of bare bones Digital Audios. If you know how to test your power supply yourself then maybe just a PS, otherwise a bare bones will give you other spare parts( plus a board if that is really what is wrong.)
Join & Write a Comment
No matter the version of Windows you are using, you may have some problems with Windows Search running too slow or possibly not running at all. Before jumping into how you can solve this issue, just know there are many other viable alternative deskt…
To share tips on how to stay ALERT and avoid being the next victim - at least not due to your own poor cyber habits and hygiene!
Finding and deleting duplicate (picture) files can be a time consuming task. My wife and I, our three kids and their families all share one dilemma: Managing our pictures. Between desktops, laptops, phones, tablets, and cameras; over the last decade…
587 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
